Fork Lock Removal On 95 FLHTCH
Old May 29, 2017 | 07:57 PM
LongBeard Outlier's Avatar
LongBeard Outlier
Stage I
Default Fork Lock Removal On 95 FLHTCH
The Problem: ignition switch won't go to full left position (Fork Lock). Key in or out, turned on/off, switch pushed up/down, front wheel turned right/left. No combination will move switch to Fork Lock. I want to repair the issue but only find "remove the switch ****" by pulling up, sticking small lever under unit, blah, blah, blah - which seems to work fine if one can rotate the **** to Fork Lock. The Solution: There must be a better solution than taking a pipe wrench to the ****, 4# hammer and chisel, 12 ga. 3" mag. with double ought buck - (just a thought). Better non-destructive thoughts appreciated. -LongBeard
mgb1
Electrical/Lighting/Alarm
May 26, 2017 11:31 AM
hdwd2000
Apr 27, 2016 03:37 PM
BugBYter
Screamin Eagle CVO Models
Feb 17, 2016 08:22 PM
rivercityslim
EVO
Jun 27, 2009 03:41 PM
jbied
Mar 8, 2009 11:34 PM
