Djm
Old Jun 1, 2017 | 03:12 AM
djohnmiller1's Avatar
djohnmiller1
2nd Gear
Default Djm
can you swap a known good ECM from one '02 Ultra to another (to test)?. and if so, anything special need to be done also? I have a rough/unstable idle and it doesn't clear up until over 2k rpm. under load, it's fine. I think it's a programming issue. Thanks.
Old Jun 1, 2017 | 04:18 AM
modular's Avatar
modular
Are you asking if you can use an ECM from an '02 Ultra touring bike on a Sportster of some sort???
Old Jun 1, 2017 | 07:25 AM
grbrown's Avatar
grbrown
Wink
You've wound up in the Sportster section, where your query may not get as good results as if you posted in the Touring section. There are also other things that can mess with the running of your engine and I recommend you check your FSM for help diagnosing problems like that. IMHO swapping ECM is no substitute for diagnosing the problem with your current one.
Old Jun 1, 2017 | 12:10 PM
1340hog's Avatar
1340hog
i don't believe ecm's are interchangable,as with cars each one is flashed with that spacific vin number.i believe motorcycles are the same way.check the throttle body wiring harness(where it attaches to the throttle body)pins,use dielectric grease.push open the throttle plate and look inside the body if its all black and dirty clean with a throttle body spray.poor condition throttle bodys will cause rough idle.
Old Jun 1, 2017 | 12:20 PM
multihdrdr's Avatar
multihdrdr
What are you referring to with the use of "Djm"
Old Jun 4, 2017 | 05:44 PM
djohnmiller1
2nd Gear
Thanks for response. I kinda figured just swapping would be too easy! Wiring has been checked. Also new intake gaskets and cleaned/decarboned throttle, intake, intake ports & intake valves (they had ALOT of carbon, but when put back together= ran the same!. I would have thought alittle improvement would be noticed! Maybe the old stage 2 kit has alot of overlap in the cams causing this. That's the way a car engine acts with a big cam. I guess I'll have to tear it down to check something like that.
Old Jun 4, 2017 | 05:55 PM
roussfam's Avatar
roussfam
In your OP you thought it was a programming issue, now you want to tear down the engine? Get it checked out at the dealer. Oh, welcome to the Forum
ezryder62881
Nov 2, 2016 08:09 PM
kjc1134
Jun 8, 2015 05:51 PM
tcataldo
Feb 28, 2012 07:11 PM
Duggr
May 16, 2011 01:10 PM
Z_Stingray
May 27, 2008 07:34 PM
