Dang shifter problem
Old Jun 18, 2017 | 08:57 AM
twistedcherokee's Avatar
twistedcherokee
Default Dang shifter problem
Well I opted for the Baker anti overshift pawl. Installed it & got it all back together & still having trouble getting it to down shift. I adjusted the pawl with the cover off so I could insure the distance of the pawl & the dowels on the shift drum & that the eccentric bolt was at 12 o'clock & moving the correct way. But took it for a test ride & was so pissed I parked it. Going to go out & try to adjust it with the cover on & see if that takes care of it. I inspected the shift drum & forks & found nothing wrong with them. Previous thread is hear. https://www.hdforums.com/forum/touri...-shifting.html I also looked at the heel & toe shifters to insure that they are not hitting anything, they are fine. Adjusted the clutch when I reinstalled everything, so I know that is good. Sometimes being a mechanic can be so frustrating. Thanks
Toby
Old Jun 18, 2017 | 10:24 AM
mkguitar's Avatar
mkguitar
the internal shift mechanism can get damaged if air impact tools are used.
if you did, look at that
mike
Old Jun 18, 2017 | 10:59 AM
Yamaharley's Avatar
Yamaharley
Is it happening when downsifting into any gear? Did any of the shift forks look bent?
Old Jun 19, 2017 | 07:31 AM
twistedcherokee
No air tools used, forks did not look bent or worn. Got busy doing yard work yesterday and Fathers day so I did not get to try adjusting the pawl . Will do that after work tonight. Thanks
Toby
Old Jun 19, 2017 | 09:08 AM
xcbullet's Avatar
xcbullet
Another great peace from Baker is the shift drum. Makes finding neutral a alot easier. But I also have there forks but don't think it's needed to shift better, I just bought the whole kit. It's alot easier to ajust paw with primary out of the way.
Old Jun 19, 2017 | 08:49 PM
twistedcherokee
It is easier, but I am not going to pull the primary back off. It's not that bad as long as the exhaust is cool. I adjusted it back just a touch, didn't seem to make a difference. Letting the exhaust cool down & try it again.
Toby
Yellow Glide
Mar 24, 2022 07:27 AM
shepdog
Ironhead
14
Mar 21, 2020 01:53 PM
dynahead951
May 29, 2019 12:59 PM
Ricktyler
Mar 16, 2015 09:03 AM
jrscars
EVO
Aug 15, 2013 08:34 AM
