Sticking throttle.
Old Jun 19, 2017 | 09:03 PM
truejdm's Avatar
truejdm
Default Sticking throttle.
I've searched all over this forum and can't find my issue. Maybe I'm just slow.
Installed new bars and the throttle is now jerky/sticking off idle. It's the tube end it self. Not the grip. I took some short videos, if someone can tell me how to post or will let me email or text them.
Old Jun 19, 2017 | 09:09 PM
jtarter's Avatar
jtarter
Not sure if you have the thumb screw under the grip. My Softail has a black star thumb wheel that can lock the throttle. Might check that.
Old Jun 19, 2017 | 09:15 PM
truejdm's Avatar
truejdm
Do not.
Sorry, forget to mention it is a 2011 Street Glide.
Old Jun 19, 2017 | 09:22 PM
sammer4u's Avatar
sammer4u
My 2015 Ultra has done that since day one. Dealer did something with it once, it was fine but came back quickly. Not sure what it is. Feels "gritty" and "sticky". Curious to hear some remedies
Old Jun 19, 2017 | 09:25 PM
truejdm's Avatar
truejdm
"gritty"
Perfect word
Old Jun 20, 2017 | 05:30 AM
caulk04's Avatar
caulk04
When I installed new bars and grips, the bars were a little big and the grips a little smaller than stock...throttle wouldn't return. It was my grip rubbing the bars.
Flap wheel on a die grinder worked nicely to slim the bars down. To be safe, I smeared some anti-seize on the bars to keep it from corroding.
Old Jun 20, 2017 | 09:32 AM
truejdm's Avatar
truejdm
Thank you for the input. It is in the throttle tube itself. Does it with the grip off the bike.
Old Jun 20, 2017 | 10:16 AM
sammer4u's Avatar
sammer4u
Mine did it with the stock grips and shortly after delivery of the bike. I have since put on the Kuryakyn ISO grips and they do it as well... Is it possible that the grips are on to far, causling a binding with the throttle, bar, and grip?
Old Jun 20, 2017 | 11:53 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Some handlebars need more lubrication under the throttle tube than others. Without, they can bind and feel gritty. Type of lubrication can also make a difference. Silicone spray is easy and effective, but not long lasting. Many do use a white grease, some prefer a waterproof grease or graphite grease.
If the throttle tube has a covered end, pushing too far onto the handlebar can bottom it out, making a very gritty sticky bindy action. Easily fixed by simply moving the throttle assembly out a wee bit. Sometimes too a bit of filing on the end of the handlebar may be needed if the throttle tube assembly cannot be moved.
Another with a throttle by wire is a rough potentiometer, the electronic part you're twisting. That's probably pretty rare.
Perhaps not so rare with a throttle by wire might be a rough handlebar where the notches are. If there are burrs, it's going to grip the tube and create bind.
Just some quick thoughts.
Old Jun 20, 2017 | 04:19 PM
beary's Avatar
beary
My 09 SG started sticking at about 15,000 miles. I took it to the dealer to "ask" what it might be. They grabbed and took the bike in back. Came out 5 minutes later and said it needed a little lube. That will be $35. I was ticked.
Try a little dry lube where the switch housing touches the throttle tube.
Beary
