Brake Fluid Change w/ABS
Old Dec 16, 2018 | 05:40 PM
  #61
ORradtech's Avatar
ORradtech
Originally Posted by Goose_NC
For records take a photo of the receipt with odo.
That would certainly prove you bought fluid but not that the ABS was flushed to their specs, IE with the tool to cycle the ABS. Thus giving them an out to blame the owner for improper maintenance.
Old Dec 16, 2018 | 07:06 PM
  #62
sixguns's Avatar
sixguns
I do my own fluid changes at home, I follow the OEM procedure using a Snap On brand vac brake bleeder. No Mess, No fuss, no dealer, no big deal. Good Times!
Old Dec 16, 2018 | 07:41 PM
  #63
blacktop37's Avatar
blacktop37
Why would someone spend all the extra money on ABS knowing it might be the difference in life or death, then ignore what HD says it takes to support the technology? My dealer charges $100.It will last 2 years.The thinking is just flush and all will be ok. Well its probably pretty good odds that it will be ok because the majority of us may never use ABS, but a few will wish they had done it to HD specs after realizing It didnt work when needed. I was in a toy run a month ago. We were going 2 abreast. I had ABS, my buddy next to me didnt. You know how those parades go, everyone tries to speed up then a little misstep at the front of the line, WHAM all hell breaks loose as everyone for a mile tries to react.WE were not going fast when the line slowed but fast enough to create panic. I hit my brakes ..straight slow down. My buddy next to me hit his at the same time, I could see first hand what non ABS does. His front wheel turned left in the flash of light screamed when it locked up. We were doing about 25. If it would have been any faster he would have gone down and would have spent a lot more than what ABS option and upkeep on it would have cost.
Old Jan 8, 2019 | 06:23 PM
  #64
TheITMercenary's Avatar
TheITMercenary
Former Sponsor
Wanted to chime in on this as I know quite a bit about this topic. The problem is much worse than just no ABS function. Unlike a "normal" (i.e. every other vehicle with ABS I've ever used or worked on) where IF the ABS system fails you still have brakes, HD bikes do NOT have braking function at all (if the HCU completely locks the valves up). What the NHTSA should be doing is requiring HD to redesign the HCU and R&R on their dime. Unfortunately either a few people will need to die and/or be forced to do this. I suspect it will never go that far, they have way better attorney's than you and I to argue to death (pun not intended) this issue.
In the meantime, I recommend flushing your ABS equipped Harley annually. The DOT 4 brake fluid specified is hygroscopic. Even worse is the fact that the gaskets on the reservoirs across pretty much all the Harleys are ridiculous sensitive to over torquing and a poor seal at best. I've flushed fluid on these bikes at 6 months that were completely dark (i.e. bikes left outside primarily).
We have a product that you can flush your ABS equipped brakes at home, exactly like the dealer does. It WILL get the old fluid out of the HCU and help prevent the "sticking" valve issue in the HCU (which by the way is a sealed/non-serviceable unit, so once it's toast it's toast).
Here to help!
Old Jan 8, 2019 | 07:21 PM
  #65
blacktop37's Avatar
blacktop37
Interesting would it work on a sporster 2018 and 17 Road King?
Old Jan 8, 2019 | 08:22 PM
  #66
GalvTexGuy's Avatar
GalvTexGuy
Here to help!
Good post, but this subject has been discussed ad nauseam in multiple threads over the last couple of years. Welcome to H-D Forums.
Old Jan 8, 2019 | 08:28 PM
  #67
TheITMercenary
Former Sponsor
Yes it will. The ITM HD2 tool is what you want. We span all the years and variants of the ABS systems.
Old Jan 8, 2019 | 08:30 PM
  #68
TheITMercenary
Former Sponsor
No worries, just trying to provide info for those that may not know this. Also very happy to help people maintain their bikes with our product via spreading the word!
Here to help. Give us a shout sometime.
Old Jan 8, 2019 | 08:49 PM
  #69
GalvTexGuy's Avatar
GalvTexGuy
Oh, yeah. I remember when you first posted about your app. I'm using the H-D Forum app which doesn't show that you're now a sponsor. Good for you! When I get on my computer, I'll be sure to look into your product.
Old Jan 9, 2019 | 07:34 AM
  #70
TheGrandPoohBah's Avatar
TheGrandPoohBah
Sadly, it will probably take death and litigation before the facts are laid out that the problem was in design and materials used. Some degree of moisture should be expected in a hygroscopic solution, the use of materials that react adversely to such conditions should be avoided, and for ABS module failure to result in total and complete loss of braking is not common among other manufacturers and is completely unacceptable.
