Water leak
Old Jun 22, 2017 | 06:37 AM
CapeGlide's Avatar
CapeGlide
Default Water leak
Yep, you read that right. For several weeks after returning from a trip, spending the last day riding in rain. I noticed a leak on the left side of the bike. Behind the primary, in front of the rear tire. First thought it might have been shock oil, but looked and felt like water. Everyday the puddle would be there. There are two small nuts holding a protective cover on the bottom of the swing arm. I removed them and the water poured out of the holes. Somehow, the water was sucked into the swing arm frame. Is this a design flaw? Anyone experience this before?
Old Jun 22, 2017 | 06:48 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
There are a fair number of comments about this on other forums, and apparently a Harley service bulletin on it too.
This should link you to an apparently unofficial "bulletin" regarding this problem:
http://www.hdtalking.com/attachments...t413-pdf.3492/
Old Jun 22, 2017 | 06:55 AM
Schex's Avatar
Schex
The belt guard is blocking the drain hole for the swingarm, drill out the guard and make sure the drain hole is open.
Old Jun 22, 2017 | 11:50 AM
liquidr1's Avatar
liquidr1
what year bikes does this affect. I have never heard of this issue or service bulletin
Old Jun 22, 2017 | 12:10 PM
slider1156's Avatar
slider1156
I had about 20 ounces in mine when I replaced my belt
Old Jun 22, 2017 | 12:26 PM
GTK's Avatar
GTK
I remember reading about belt guard blocking swing arm drain hole on touring bikes back in 2009 with the new frame. Lots of threads on this.
Old Jun 22, 2017 | 08:08 PM
CapeGlide's Avatar
CapeGlide
Mine is a 14 limited.
CVO18
Jun 8, 2024 01:20 AM
Uncle Larry
Aug 1, 2016 11:01 AM
MichiganMikey
Dec 14, 2013 01:44 PM
programdirector
Oct 18, 2012 09:00 AM
skunk237
Sep 13, 2010 10:04 PM
