I've seen the light
Old Jun 28, 2017 | 09:21 AM
From_Behind's Avatar
From_Behind
Originally Posted by Nomadmax
See, that's the trouble with airplane pilots. They all want to solve problems before they come up instead of taking care of stuff like this on the journey
I've been working on my sense of adventure, but I just keep screwing it up!!
Old Jun 28, 2017 | 09:25 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by From_Behind
And, even if you never change it, I can guarantee you that it will definitely work all the way until it doesn't! 😂
Yep ... ans astute observation on your behalf sir :>)
Old Jun 28, 2017 | 09:55 AM
skratch's Avatar
skratch
Originally Posted by lp
If HD releases a M-16 for 2018 I'll have only owned this one for a year.
is there enough room in the hd heads for 16 valves and the resulting actuating mechanisms? or is hd coming out with a 4cyl, 4 valve per engine next?
Old Jun 28, 2017 | 10:26 AM
hattitude's Avatar
hattitude
For years, Harley didn't have ABS... also, in recent years, Harley was using DOT5 brake fluid....
Without ABS and with DOT5 fluid (non-hygroscopic) you could go years and years without noticing any bad affect from not changing the brake fluid...... It didn't mean the fluid wasn't breaking down or in need of replacing, you just didn't notice any catastrophic consequences.... probably the same with cars using either fluid, and without ABS....
Since DOT5 doesn't play well with ABS, all cars and motorcycles with ABS needed to switch back to DOT4 fluid (hygroscopic)... add the complexities of the valving involved with ABS, and the need to keep the fluid fresh became important....
I still think the HD ABS shouldn't fail in a way that makes the brakes inoperable, but design/engineering aside, the HD ABS issues have spotlighted this entire debate...
As with any safety requirement, most manufacturers will set a requirement that gives a good safety margin. That leads me to believe that 2 years is probably more frequent than actually necessary. But I don't have test data to show that 4 yrs (enter your best guess here) is OK, so I'll stick with the 2 yr recommendation...
When I learned of all this hygroscopic v non-hygroscopic fluids and ABS and changing fluid, etc, etc.... I got off my butt and changed the brake fluid in both my '03 Heritage (non-ABS w/DOT5) and my '12 Limited (ABS w/DOT4)...
I owned both since new and neither had ever been changed... 3.5 years on the '12 Limited and 12.5 years on the '03 Heritage...
The Limited fluid looked as bad as the Heritage fluid...
Based on all I've read and my own experience, I've now added the brake fluid change to my maintenance schedule ......
Old Jun 28, 2017 | 12:30 PM
Joe12RK's Avatar
Joe12RK
what we should be changing is our fork oil every 10k miles....
Old Jun 28, 2017 | 12:32 PM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
I don't understand why a bike needs the brake fluid changed, yet an automobile doesn't. Not questioning the validity of the recommendation, I just don't get it.
Old Jun 28, 2017 | 12:43 PM
firedog928's Avatar
firedog928
You are supposed to change the brake fluid in your car it's just that most people don't do it
Old Jun 28, 2017 | 04:07 PM
jmorganroadglide
According to goggle, the jury is not in agreement. The only reason given to change brake fluid is to prevent the buildup of water in the brake fluid. May be a problem in some areas but I have never seen it.
Old Jun 28, 2017 | 04:31 PM
GalvTexGuy's Avatar
GalvTexGuy
I said the same thing in one of the other brake fluid threads. I service my own vehicles, but my wife takes hers to the dealership for everything. Her last five vehicles (Toyota Sienna) were all bought and serviced at the same Toyota dealership and they all were close to 200K on the clock. She's an RN home health nurse, so she drives a lot. I asked her the other night if the dealer has ever suggested her vehicle's brakes be flushed. She told me they have not, so I have to believe a brake fluid flush is not part of Toyota's scheduled maintenance or, believe me, they would have suggested it because they damn sure hit her up for every other costly maintenance item.
From using Google, like you, I found some automobile manufacturers do have brake flushes as part of their scheduled maintenance, but some do not, with Toyota and GM being at least two that do not.
Old Jun 28, 2017 | 04:40 PM
ORradtech's Avatar
ORradtech
Suck a turkey baster full out of your car master cylinder and put it in a clear glass container. Now put some fresh fluid in another clear glass jar. Compare the two. If the old is clear and maybe only slightly yellower than the new you're good. If it's cloudy, brownish or both you've now seen it.
I don't understand why people are fighting this. It's inexpensive, literally $10 dollars or so, and easy to do so why not? Loss of braking performance happens so gradually you won't notice it but changing the fluid will likely show an improvement.
