After reading all those threads on changing your brake fluid every 2 years and what can go wrong if you don't, I have booked my bike in to do the same.
I was considering stretching it to December before doing it - but that would make a full 3 years since I got my bike before flushing the brake fluid - which I judged might be pushing my luck.
Better to get it done now - only 6 months overdue rather than tempt fate.
On my '09 RG I never had it done. I physically tested the abs every time I rode it. Was still working a month ago when I traded it in.
You might have been pushing your luck a bit there as it is a well known fact that brake fluid absorbs moisture over time, to the detriment of performance.
Not saying it shouldn't be done, just saying 2 years is pretty early. Anyways I asked for a fluid change about 4 years in and my indy said why? (Dealer mighta said different)Is it giving you problems? For sure changing it is a good idea I'm just suggesting 2 years might be overkill.
All I'm saying is that the owners manual says 2 years. The service manual says 2 years. The manufacturer is sending out reminders that say 2 years. 2 years is sounding pretty good right about now, no?
Sure, do what makes you feel good. Lotsa bikes, losta years never changed brake fluid, no issues.
