Oil problems
Old Jul 4, 2017 | 08:26 AM
Rob76's Avatar
Rob76
Stage I
Default Oil problems
I have a 91 Electra Glide and if it sets for a while all the oil drains from the tank into the motor what can I do to stop that? Thanks
Old Jul 4, 2017 | 11:42 AM
Bingee's Avatar
Bingee
Oil is leaking past the check valve in the oil pump. It's either dirty or worn out You should remove the oil pump. Clean it out and replace the check valve ball (looks like a ball bearing). The service manual for '91s shows how. The ball can be replaced with pump on the bike and its chamber cleaned. But if there's any tiny debris in the pump it will only leak again. It's old. It probably needs it.
Old Jul 4, 2017 | 12:25 PM
Rhino-1's Avatar
Rhino-1
Great advice--and maybe look at a new pump, since you're there.
Crabchuck
Milwaukee Eight (M8)
21
May 12, 2018 12:17 PM
Wi_Duker
Apr 23, 2017 04:09 PM
STN
Engine Mechanical Topics
Dec 23, 2016 05:01 AM
glidein wide
EVO
Feb 26, 2016 06:17 PM
istoleurpen
Jun 8, 2006 08:40 AM
