What were the first upgrades you performed on your touring model?
Old Jul 7, 2017 | 07:26 AM
  #81
checkers's Avatar
checkers
Originally Posted by elPrez
OOOO, and replace the crappy shift linkage joints with heim joints.
This is an often overlooked item. For the money it's one of the best upgrades you can due. Upgrade adds reliability and much smoother shift action. I change trans fluid to synthetic gear lube at the same time. Shift is improved drastically.
Originally Posted by davewear
JES fangs and 7" LRS shield. The batwing can be great but it doesn't come that way....
I installed fangs on my RK. They work very well from the standpoint of buffeting. I take them off from June through September. They trap too much heat and shows worse after interstate run.
Old Jul 7, 2017 | 08:29 AM
  #82
F150HD's Avatar
F150HD
Originally Posted by Dennis Lett
Performance, aesthetics, comfort, aftermarket goodies or necessities?
Because, I like everyone, focused on the first 4 and now I'm having to deal with the expense of the last. I already put in a set of Sta Bo bushings I got cheap. Now I'm dealing with the major design flaw of the early Twin Cams, tensioners. I already installed a Hayden Primary tensioner. Big difference and no more adjustments. Now, I picked up all the parts to go to hydraulic cam tensioners at the end of the season. I decided to go with a later model cam plate for the inner roller chain and in going to use Cyco tensioner shoes for long life,
so you're saying you bought the upgraded HD cam plate but are replacing the shoes on it?
__
do those just screw on/off the shift linkage?
Old Jul 7, 2017 | 09:09 AM
  #83
FLHBK's Avatar
FLHBK
For me it's all about fitment... Make sure you're comfortable. The previous owner of my '12 Limited was about 8" shorter. So I started with a new seat, windshield and foot controls. After about 6K miles... changed bars to 10" twin peaks.
The bike already had a stage 1 and lots of shiny additions so that kept me pretty happy for another year. I swapped those dreadful air shocks fora set HD adjustable. By then It was time to consider performance.
I Finished up the last few thousand miles of the season with the PCV. It was a nice bump HP/Tq but by then I was ready for decat and cam swap. Now it's pretty dialed in. The Woods 222 were just what I needed for a little sporty solo riding and two up touring. Plus it adds a nice little lope at a slower idle.
Now i just fill it up and ride.
The only thing else I will probably do is invest in a dyno tune next year after testing a few different canned maps. The only other I would consider is revisiting the suspension. But only if I find some cash burning a hole in my pocket because at that point there is no point in cutting corners. That's my list... looking forward to reading your replies.
Old Jul 7, 2017 | 09:21 AM
  #84
OldPhat's Avatar
OldPhat
Two worthwhile add on accessories for me were, E-Glide Goodies footboard extensions,
& two HD extended shift levers. Now I have happy size 10 5E feet.
John
Old Jul 7, 2017 | 09:27 AM
  #85
0ldhippie's Avatar
0ldhippie
First: bars, seat and windscreen
second: suspendtion
Third: the options are endless... ride and look at it, change what ya don't like...
There is very little still stock on my bike...
Old Jul 7, 2017 | 10:26 AM
  #86
INJEKTER's Avatar
INJEKTER
a good stage one....a great seat...and forward controls.....the ride and enjoy simple
Old Jul 7, 2017 | 11:49 AM
  #87
470004's Avatar
470004
HD's High-flow Air Cleaner and Screamin Eagle's 4" Street Cannon Slip on mufflers.
Old Jul 7, 2017 | 12:26 PM
  #88
elPrez's Avatar
elPrez
yes or you can also replace the whole boring bar with something nicer, lots of options out there.
Old Jul 7, 2017 | 04:04 PM
  #89
Sierra977's Avatar
Sierra977
Happen to remember the size and source for Heim joints you used?
Old Jul 7, 2017 | 05:39 PM
  #90
CJeep's Avatar
CJeep
At 6' 3", bars, extended shift & brake, and footboard relocation were mandatory. Stock police seat is great for us tall guys.
Aside from that, which I did over about the first 4 months of owing it, the first thing I did was an FP3
For the $ its a no-brainer in my book. Even the improved stock tune is way better than stock, and, for TBW bikes, you can alter the throttle sensitivity, getting rid of the annoying nature of starting from a stop with the stock settings.
Its flexible for stage 1 mods and cams now.
Its like a different bike, all for about $300.
