2002 FDXDWG electric problem
Old Jul 8, 2017 | 12:42 PM
nodhtims's Avatar
nodhtims
Stage I
Default 2002 FDXDWG electric problem
Well running the bike the positive side of the battery came loose intermittently, causing back firing and finally dying.
Replaced battery and made connections.
Green blinker lights come on immediately in speedo
Turn ignition on, no reading on odometer mileage, brake light comes on, will not turn over when hitting starter, can not read codes or anything in odometer window. Check all fuses, ok. Neutral light & oil light come on, horn works, no blinkers
Old Jul 9, 2017 | 12:51 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Is there a question in there somewhere?
Old Jul 9, 2017 | 03:42 AM
6 gun's Avatar
6 gun
Check the connection of the hot wire to the starter see if the hot wire is loose in the
lug. If that don't fix the problem, I would take it to a trust worthy Indy and get it checked out.
Old Dec 4, 2021 | 04:52 PM
Graphite07's Avatar
Graphite07
6th Gear
same problem
only the the back lights come on for the gauges
no head light
no tail light
no blinkers
no start
no nothing
don’t hear the fuel pump priming or clicking.
nothing works
has anyone figured this out
2009 XR1200..
bike started up fine for work. Got to work turned the bike then it would not start up again
I’m so tired. Of the XR1200
any help
Old Jun 15, 2023 | 07:35 PM
JimiIsFrustrated's Avatar
JimiIsFrustrated
Stage II
Originally Posted by Graphite07
same problem
no head light
no tail light
no blinkers
no start
no nothing
nothing works
2009 XR1200..
any help
Has this been rectified? If so, how? Bc I have the same problem....cannot figure it out
Old Jun 15, 2023 | 07:52 PM
Graphite07's Avatar
Graphite07
6th Gear
it was the ignition switch. The 3rd wire burned up.
soon as I put the after market ignition In and connected the wires the bike came back to life:
motochick218
26
Feb 19, 2025 11:39 AM
rmlentine
Jul 23, 2018 10:01 PM
ABN_Daddy
Jul 27, 2017 12:59 PM
zkeisler
Jan 2, 2014 07:27 AM
Jerseyrider
May 14, 2009 10:15 PM
