wind deflectors question
Old Aug 15, 2017 | 08:53 PM
  #81
jbfb's Avatar
jbfb
So I did it. I ordered the wings, a 1.5" lift and the deluxe kit (for the tank rear.)
Put it on today. After having watched the videos a few times it went SUPER smooth EXCEPT, it took me a few minutes to realize the wings needed to be mounted with the angle DOWN. I initially had them (on the correct side) so the angle was on top (basically covering the bolt where it's mounted.)
The tank lift kit, front and back, was super simple and right off the bat I'll say that for the 50$ I love the changed look. When the bike is sitting on the side stand, the opposite side REALLY looks noticeably nicer, exposing more of the motor.
Here's a little catch. My RGU came with these;
https://www.harley-davidson.com/stor...-deflector-kit
But after looking at them a bit they really seem to me that they're designed to push the wind up, maybe to flow OVER the rider? But it appears to me they definitely would not let any or much wind continue on to the motor. So I pulled them off and replaced them.
I did go for a little ride, just around the neighborhood so never over 45. I can't tell if the buffeting is different, but at 86 degrees during the ride, if pressed to answer, my legs/crotch did not feel like they were getting as much engine heat.
The rear of the tank (as mentioned in the other posts) does push up into my upper thighs a bit more, but doesn't encroach on my, encroach-ables. I'm sure in time I won't even notice it.
I'll add more info as/if it becomes apparent.
Old Aug 16, 2017 | 05:48 AM
  #82
OldMike's Avatar
OldMike
I had DK wings mounted like this:
Old Aug 16, 2017 | 06:35 AM
  #83
frenchbiker's Avatar
frenchbiker
Originally Posted by DK Custom
In the black they pretty much are inconspicuous...one of the reasons it is hard to get photos of them installed is that they disappear against the black frame.
I have your large ones for lifted tanks and I like them. However, I'd MUCH prefer if they were black, like the small ones, and not charcoal, although your site describes them as black.
FEATURES:
Made from American Steel
Durable Black Powder Coat Finish
Reduces Rider & Passenger Buffeting
Re-Directs air on to the engine for better Cooling
E-Z BOLT-ON INSTALL - DOES NOT REQUIRE REMOVAL OF TANK
E-Z Install, Step-by-Step Instructions included
Made in The USA
Old Jan 26, 2019 | 12:54 PM
  #84
LXT's Avatar
LXT
Sorry to resurrect an old thread.... But im thinking about getting the HD wind deflectors for my heritage along with a LRS recurve, so heres my question? these help with wind buffeting but cause engine temps to rise??? I am wondering just how that can be? - if that wind is coming in under the shield and the tank is causing the air to ricochet up into the riders chest thus moving in an upward fashion to cause ones helmet to float or cause head buffeting (easy on this one) then that air was never really helping to cool the engine to begin with - right? or what percent was cooling the engine?
Has there been any wind tunnel study done before and after on this stuff? I get how the wind deflectors would work & the recurve windshield - but under movement I just cant see how the engine would have an increase of 25% in the heat range by using wind deflectors....
Thoughts?
White Glide
2014-2024 Touring Models
51
May 4, 2018 10:59 AM
JClaud
26
May 4, 2014 08:52 AM
Alamomann
Aug 21, 2013 06:58 AM
DannyZ71
Sep 4, 2011 11:44 AM
dan69co
Sep 23, 2007 05:55 AM
