Ignition help
Old Jul 17, 2017 | 02:40 PM
Rob Wild's Avatar
Rob Wild
Stage I
Default Ignition help
So I pulled the ignition to put in fog lamps. Had to so I could access the dash panel for the switch install. No idea why, but it won't re-install. The **** just rotates, not catching anything. The front end rotates without locking to the left. It is stuck halfway there, won't come out to check alignment inside the tube either. Stressing out. Need advice, thanks. '17 SG
Old Jul 17, 2017 | 02:47 PM
ORradtech's Avatar
ORradtech
Do a YouTube search for Harley ignition removal. There are a bunch. Also several threads on this site a general Google search will find.
Old Jul 17, 2017 | 06:38 PM
Veekness's Avatar
Veekness
The factory service manual has the procedure, also, however, it doesn't cover when things go to hell in a handbasket with that assembly...and it will, inevitably. I recall the last time I had the same problem you are describing, I had to try the ignition shaft in several positions before it would lock in as it should. I also used the ignition tool from George's Garage...drove me to drink...
Old Jul 17, 2017 | 07:42 PM
Vernal's Avatar
Vernal
Hope this helps:
Old Jul 17, 2017 | 09:40 PM
purpledeuce's Avatar
purpledeuce
Push the button on the bottom, may have to turn the key a little. It will come out, I did the same thing
Skinon
Jul 8, 2019 09:46 PM
kryingame
Sep 14, 2013 10:50 PM
flhxmc
Feb 22, 2013 09:53 AM
SCOM65
Jun 24, 2011 03:32 PM
jeh3169
Nov 22, 2009 09:01 AM
