Street Glide Question
Old Jun 9, 2007 | 03:27 PM
deuce437's Avatar
deuce437
5th Gear
Default Street Glide Question
Hey guys, traded the Deuce in for a used 07 Street Glide and love it. But I've had it for about a week and I'm getting a sqeaking noise coming from the front wheel. It does have after market wheels. Any suggestions on what might be the problem. I was told that all the add-ons were done at the dealership. Thanks
Old Jun 9, 2007 | 03:33 PM
Bryan TTM's Avatar
Bryan TTM
Default RE: Street Glide Question
wonder if it could be the internal spacer in the wheels...squeekin could be brake or wheel related...elaborate....welcome to the forum man
Old Jun 9, 2007 | 03:34 PM
Bryan1724's Avatar
Bryan1724
Do you hear it while only going slow, and does it go away when you put on the front brake? I've developed a squeak also in the front. Had new tires put on and now I have a slow speed chirp/squeak. Mine goes away when I put the front brake on. Guess I have a pad barely touching the rotor now.
Old Jun 9, 2007 | 05:03 PM
deuce437's Avatar
deuce437
5th Gear
I can only hear it when moving the bike to the front and back slowly. And it seems like its at the same point in the rotation of the wheel.
Old Jun 9, 2007 | 05:26 PM
Timex's Avatar
Timex
Switch rotors.Left to Right, Right to Left.
Old Jun 9, 2007 | 05:27 PM
smknflms's Avatar
smknflms
..jack front wheel off ground..spin wheel and see if you can isolate noise ..could be bent rotor..bad caliper alignment..spacers..axle too tight binding up wheel..
Later
Old Jun 9, 2007 | 05:42 PM
mrsr71's Avatar
mrsr71
Maybe warped rotors. Switch to "floating" and the problem will disappear.
or
As mentioned above, switch sides.
Old Jun 10, 2007 | 05:42 AM
PapaTravis's Avatar
PapaTravis
I would swap rotors left to right first. It wont cost you anything, and if that doesn't fix it, go with floaters. For me, the swap and some silicone/foam, was put in the cast wheel. No more noise for me, to this point.
Old Jun 10, 2007 | 05:52 AM
kansasroadking's Avatar
kansasroadking
Papa, what's the purpose of the foam in the wheels??
Thanks,
K.
Old Jun 10, 2007 | 06:03 AM
PapaTravis's Avatar
PapaTravis
On cast wheels they are not sold wheels and the chrome dome thing will emit a harmonic sound, like a squeal. A year ago, before the service bulletin about swapping the rotors left to right, right to left, my dealer put foam/silicon in the void, and that stopped the squeal. When the SB came out, I had them swapped. When the swap was done, the brake drag noise I heard since I bought the bike, was gone. When you ride at a slow rate of speed, it is like a drag noise, that stops when the front brake is applied. So, for me, the silicon/foam stopped the squeal when applying the front break, and the rotor swap stopped the drag noise. Best thing, it cost me nothing. Sure, I could have gone to floating rotors, and new, better pads. But I didn't want to spend the money, until I needed to replace the worn out pads.
I have a rk custom, with the cast wheels. If you have the wire wheels, you wouldn't need the void to be filled, because you don't have the same type wheel. But the rotor swap would probally help, if you have any noise up front. JMHO. Hope this answers your question, kansas!
