Another compensator question
P.S. Not sure who's lifters you have in there, but I can tell you that I had the opportunity to experience Jims lifters as well as the stock oem Harley lifters. Both my applications I had replaced those as mentioned with the S&S Premium, and there was a big difference in how quiet the engine ran with the S&S Premiums. Quietest running lifters i've ever experienced.
I didn't read anything in your posts about an aftermarket fuel management system. Are you running this bike with the factory oem fuel management system?
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
Also on amazon.com...
What you describe is very likely either detonation or a valvetrain issue of some sort.
What compression is your 107 motor?
Even though you tried lucas octane booster i found from trying it 1st hand its not great a boosting octane like for example real lead supreme 130 thats the real lead used to increase octane in leaded fuel 40yrs ago.
I suggest that because if its detonation you could end up chasing your tail & spending a lot of time/effort/money going after other things if it was simply the motors setup & tune (compression/cam choice/ign timing curve) requiring considerably more octane to stop the detonation or maybe retarding timing a few deg to stop it though doing that will likely reduce perf/pwr/trq too.
Go to WildBillsCorvette website to buy real lead octane booster,its not cheap but it does job the lucas cant i found 1st hand in hi perf hi compression old school big block chevy's i own & build for other people too.
Heres a link to the real lead booster that you can mix to over 100octane lvl & still comes out to costing less per gal then buying race fuel of same approx octane lvl.
http://www.wildbillscorvette.com/OctaneSupreme01.htm
Scott
