Emissions testing
Old Jun 11, 2007 | 04:31 AM
Bryan1724's Avatar
Bryan1724
Default RE: Emissions testing
ORIGINAL: PapaTravis
I thought '06 had one o2 bung?
Like I said I could be wrong, on the first year for the O2 bung being 07 in the H-D's. If 06 was the first year then that's as far back as they can go. Because without a O2 bung being in the pipe from the factory they can't make the emission testing crap stick on the older bikes.
Old Jun 11, 2007 | 04:41 AM
PapaTravis's Avatar
PapaTravis
Thats what I am thinking. Anyone with a '06 want to let us know if it has a o2 bung?
Old Jun 11, 2007 | 05:01 AM
Bryan1724's Avatar
Bryan1724
Papa, This is what I can tell you thatis fact. If it did not come on your bike (or car for that matter)from the factory, then they can't make you put it on to pass a emission test. This I know is true.
Old Jun 11, 2007 | 05:07 AM
PapaTravis's Avatar
PapaTravis
Sweet for me!!!
Old Jun 11, 2007 | 08:44 AM
impact02's Avatar
impact02
my 06 did not have a 02 bung in the stock pipes but the mufflers have converters.
[IMG]local://upfiles/21465/B01E10914D2C48ED90BDA5EC032EB8B4.jpg[/IMG]
Old Jun 11, 2007 | 09:00 AM
MiniMe's Avatar
MiniMe
No o2 bung on the 06's
Old Jun 11, 2007 | 10:48 AM
Mikind7's Avatar
Mikind7
Only 06 Dynas had o2 sensors
Old Jun 11, 2007 | 10:50 AM
norskehd's Avatar
norskehd
With the exception of the VRSC (V-Rod) family, 2007 models do not use a catalyst type of muffler. The use of Oxygen sensors in the header pipe to providefeedback to the fuel injection system eliminates the need for the catalyst mufflers on regular production bikes.[/align][/align]Catalyst mufflers are required on 110 cubic inch performance kits and on CVO (Screamin Eagle) models that have the 110 cubic inch motor.[/align][/align]2007 models are 50 state compliant for California and all other states even without cat's.[/align]
Old Jun 11, 2007 | 03:35 PM
Firetender's Avatar
Firetender
ORIGINAL: HogmanFLHX
California never had any plans but 2010. Manufacturers that make more than 300 bikes/year will need to meet certain standards towards that goal every year between now and then. (Hence the new engine and lean condition.) And for those of you living elsewhere, it is a federal standard so you will be effected also. If you build your own it should be exempt for as long as "you" own it.
Not true. California emissions testing was scheduled to begin April 1, 2007. A concerted effort by the president of the Cal HD dealer's association resulted in CARB backing down at the last minute. They agreed that motorcycle emission testing would be a huge costly-to-enforce nightmare. There are new emission standards for manufacturers as you said, based on numbers produced. Are you an ABATE member and/or supporter?You'd be supporting motorcyclists rights and know a lot more about this important topic.
Old Jun 11, 2007 | 07:47 PM
HogmanFLHX's Avatar
HogmanFLHX
ORIGINAL: Firetender
Not true. California emissions testing was scheduled to begin April 1, 2007. A concerted effort by the president of the Cal HD dealer's association resulted in CARB backing down at the last minute. They agreed that motorcycle emission testing would be a huge costly-to-enforce nightmare. There are new emission standards for manufacturers as you said, based on numbers produced. Are you an ABATE member and/or supporter? You'd be supporting motorcyclists rights and know a lot more about this important topic.
The testing was for manufacturers only and not the consumer to ensure they were moving towards the standard. I work for the state and that's all I will say. ABATE does do a good job of informing cyclists and so does this forum.
