Erratic Volt Gauge
Old Aug 14, 2017 | 01:59 PM
TheBaron's Avatar
TheBaron
3rd Gear
Default Erratic Volt Gauge
Hey there everybody,
I've looked a number of times and searched every string i could think of, but can't find my issue. Some issues others have had to deal with were close although not quite the same.
My 1998 Ultra has had an issue with the volt gauge moving from near 14v down to 8v. The needle swings rapidly up and down the scale. It'll hold steady sometimes and other times it drops to 8 and doesn't budge until I restart and it stays up near 14v -- for awhile. Engine temp and air temp doesn't seem to be a factor.
I had the stator replaced last August. Everything was cool for the 120 mile ride home but within a week the gauge was swinging wildly again. This spring I installed a new battery and all was good until about a month ago. I've checked the regulator with both a test light and meter and all was good. Stator puts out about 56 volts. Battery is receiving a bit over 14 volts at around 2500 RPM. All grounds seem clean, dry and tight. I religiously use a tender every time the bike gets parked.
Any ideas?
Doug
Old Aug 14, 2017 | 02:06 PM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
How about the Voltage Regulator, has that be changed ? A simple volt meter on your battery watching it for 5 minutes and seeing if drops or not. If it stays at 13.4 - 13.8 while hitting you bake, signals, hazards while its running, then it may be your gauge. And of coarse make sure your battery terminal are sung...
__________________
LONG RIDE SHIELDS
www.longrideshields.com
Old Aug 14, 2017 | 02:08 PM
Vernal's Avatar
Vernal
Welcome to the Forum.
Sounds like you may have a Voltage Regulator going out.
This section of the Forum has "Stickies" that will guide you to check the charging system:
https://www.hdforums.com/forum/elect...ting-alarm-43/
Old Aug 14, 2017 | 02:10 PM
TheBaron's Avatar
TheBaron
3rd Gear
The only odd thing, electrical, is the right blinker. The indicator doesn't light up on the dash. More of an irritation than anything else, I figured.
Old Aug 14, 2017 | 02:15 PM
TheBaron's Avatar
TheBaron
3rd Gear
I was leaning toward the VR but was hoping to be wrong, donchaknow. Since it passed the usual tests, I wanted the cuplrit to be the gauge. Time to bust out the checkbook again, eh?
Old Aug 14, 2017 | 02:28 PM
470004's Avatar
470004
I am not sure if this is the same problem as your. A friend bike would not start. The battery is always hooked up to a battery tender(not a Deltran). The battery tender was showing battery fine. He was bring the bike down to an indy shop to have some work done. We jump started it as per the manual. Riding down to the shop, he noticed the volt meter constantly jumping around. We get to the shop and tried to start the bike up again, nothing. The shop check the battery, it was a dead. It also turned out the battery tender was not functioning correct.
Old Aug 14, 2017 | 04:28 PM
ORradtech's Avatar
ORradtech
Seems to me you need to determine if the issue is the meter or the charging system.
I'd rig a set of wires from the battery to a DVM that I could see at the same time as the dash merer. If both meters react the same way, the problem is charging system. If the dash meter drops but the DVM stays constant the issue is the meter or its wiring/connections.
If you determine the charging system is at fault I would lean toward the VR as well but would hesitate to buy parts until I did a complete, systematic test of the entire system.
Has anyone asked if you've pulled DTCs yet?
Old Aug 14, 2017 | 05:15 PM
TheBaron's Avatar
TheBaron
3rd Gear
Thanks for the input. Nobody mentioned DTCs yet, but I pulled them a couple days ago. All it had stored was a 56, the cam/crank sensor code. The tender is from Harbor Freight, btw. Not the highest quality, I realize.
Doug
Old Aug 14, 2017 | 06:26 PM
markwolula's Avatar
markwolula
+1 on the above ....
Old Aug 14, 2017 | 06:57 PM
voodoodrug's Avatar
voodoodrug
try tapping the guage. dead give away.
I replaced/upgraded to ecycle stator and vr 2 winters ago and guage started acting up , all over the place , then good for awhile. I knew i had gone through every thing carefully cause I did the work.
