What does this mean?
" It doesn't fall on it face anymore at WOT it just doesn't feel like it has any power either. "
Question:
A) At what approx rpm does it feel as though it's dropping off power too early?
B) And does the power drop off happen in any gear or worse in like in for example 3rd or 4th gear vs 1st & 2nd gear?
Things to chk out:
1) Maybe fuel filter is partially clogged.
2) Real dirty airfilter or an air filter that was cleaned or replaced recently thats been clogged/fouled with oil from crankcase breather.
3) Or could also be if someone applied for example K&N filter oil to a non K&N type filter thats not designed to be oiled post cleaning which will significantly restrict airflow limiting the motors top end/upper rpm power & perf.
4) Has the bike been sitting for any length of time where possible fuel (esp with 10% Ethanol) has degraded/is partially bad in which case i would drain tank,refill with fresh known good fuel along with 9oz of Chevron Techron (CONCENTRATED VERSION!) & see how that does. (Techron's Concentrated version is a more concentrated stronger cleaner then Seafoam)
5) If the bikes got a fair amount of miles on it or is more then a few yrs old tired plug wires can hold back top end perf/power too.
So if thats the case i'd rec replacing them since they are cheap and easy to replace to go along with the new plugs you just installed.
6) Could also be an issue with a fuel line to and or from f-pump in fuel tank have partially come loose and or have small hole/s in one of the fuel lines reducing fuel pressure & or fuel flow which happens due to vibration.
7) Not as likely to be the issue is if the fuel pump is on its way out not operating @ full efficiency/full pressure so have the fuel system pressure checked to ensure it's up to spec.
Good luck.
Happy motoring!
Scott
Then pull and look at them again, and lets go from there.
I cleaned the air filter a couple days ago. It was a round screaming eagle air filter. blue rubber with white element and blue lines in it. I sprayed it with degreaser, lightly scrubbed it with a toothbrush and then rinsed it out and blew the water out with air from the inside out. Hung it in front of a fan for an hour and put it back in. I will be getting a K&N when I can afford it but for now the old one will have to do. Considering new plug wires. And Of course a oil change asap.
Your plug issues do look like deposits, for sure. You need to burn a few tank fulls thru it, no doubt. Don't be afraid to twist it up on some long stretches, and burn the soot out of it! Get it up to temp and cruise. Don't you have someplace you would like to go - a couple of hours away? Do it!
