Harley Locking Docking Hardware Quesuons?
Old Sep 1, 2017 | 05:19 PM
claytucc3's Avatar
claytucc3
Default Harley Locking Docking Hardware Quesuons?
So I am putting together my new tourpack. I am installing the HD locking latch set. For a tourpack it is supposed to be installed on the right side. The problem is, it simply doesn't fit! It will clasp on the peg but you can't close the latch without a lot of force. Once it is closed, you need a hammer to undo it. Has anyone had this issue? What have you done to remedy it?
Old Sep 1, 2017 | 06:41 PM
slapshot12's Avatar
slapshot12
On the bike side, the back mounts aren't perfectly round, they're ovalish. They can rotate to give a snug fit. Just loosen up the screws on the end and rotate it little until it fits.
Old Sep 1, 2017 | 06:46 PM
TriGeezer's Avatar
TriGeezer
Yeah...I discovered that myself after reading the instructions.
Old Sep 1, 2017 | 08:23 PM
claytucc3's Avatar
claytucc3
Well that worked great! I loosened them put the tour pack on and then tightened them. Works perfect now!
Old Sep 2, 2017 | 12:38 AM
Billman812's Avatar
Billman812
Thnx for the reply slapshot, I've been frustrated by this too
Old Sep 2, 2017 | 05:50 AM
Hate Work's Avatar
Hate Work
You mean people only finish reading the instructions after they have installed something wrong?
Old Sep 2, 2017 | 11:11 AM
claytucc3's Avatar
claytucc3
To be fair, Harley instructions suck! That's why nobody ever reads them.
Old Sep 2, 2017 | 11:43 AM
Veekness's Avatar
Veekness
No, actually, they're excellent. But they're also detailed and accurate. Most people lose their minds reading them because of this. But they aren't You Tube videos which pretty much does everything for you.
Old Sep 2, 2017 | 12:16 PM
claytucc3's Avatar
claytucc3
If you truly believe that, you never attempted to install a Harley Boom amplifier into a 2012 Streetglide using only the provided instructions. That one even stumped actual HD mechanics. Oh, and it was technically plug and play. Except you literally needed to disassemble wire looms and harnesses, move around wires in the harnesses. I learned a lot about my glides electricsl system though.
Old Sep 2, 2017 | 12:30 PM
Hate Work's Avatar
Hate Work
Then you ought to try Kuryakyn. They make HD look like the best!
