Ignition question??
Old Sep 3, 2017 | 11:14 AM
IBAHOG's Avatar
IBAHOG
Default Ignition question??
2017 RGS at times I can trun the ignition on and the little engine & oil lights comes on but no neutral light even when it's in neutral and it's just like kill switch is off but it's in the on position and does nothing... I move the ignition and kill switch a few times and neutral light comes on and it cracks..but never know when this is going to happen.... kinda got me a little scared to do some rides ...call the dealership they not had any problems like that ..... has anyone else???
Old Sep 3, 2017 | 11:42 AM
ORradtech's Avatar
ORradtech
It's under warranty.
Does it matter if they've not heard of it?
Take it in and make them look at/fix it.
At a minimum you're getting your issue on the record...
Old Sep 3, 2017 | 08:06 PM
Max Headflow's Avatar
Max Headflow
Motor will only start if the neutral light is on or the clutch pulled in. Sounds like you have a loose connection to the neutral switch. Get it fixed. Still it should start with the clutch pulled in..
conmore
Jun 5, 2019 09:12 AM
hotrod1340
Electrical/Lighting/Alarm
Nov 11, 2016 07:42 PM
softail99custom
EVO
Jul 12, 2012 07:24 PM
RK2010
May 1, 2011 07:56 PM
anubisss
Feb 12, 2007 06:14 PM
