Auto tensioner
Old Sep 7, 2017 | 06:59 PM
trunomad's Avatar
trunomad
Default Auto tensioner
can they be reset if they have ratcheted up to tight
Old Sep 7, 2017 | 07:04 PM
hellonewman's Avatar
hellonewman
Yes if you take the primary cover off and release it. The first time you give it heavy throttle, the load side of the chain will be stretched tight and the tensioner on the slack side will snug it up again. Thats the design flaw.
Old Sep 7, 2017 | 07:17 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Some good reading on these auto-tensioners will also involve inner primary bearing failure. A lot of people on this site have installed the old style adjustable or the auto -tensioners that are spring loaded to keep the tension a constant load.
Old Sep 7, 2017 | 07:25 PM
trunomad's Avatar
trunomad
I looked on google and you tube for vidio on how to do it. came up empty. is there some trick to it or is it a simple thing to do?
Old Sep 7, 2017 | 07:35 PM
skid_pimp's Avatar
skid_pimp
As stated above, it will simply tighten to the same tension the first time you get on it once it is warm.
But to answer your question, the easiest way is:
1. Drain and remove outer primary
2. Remove stock auto tensioner
3. Collapse stock auto tensioner, and zip
4. Reinstall
5. Cut zip the
6. Reinstall outer primary
7. Remove derby cover
8. Refill primary
9. Reinstall derby cover
10. Wait for it to overtighten again
Old Sep 7, 2017 | 07:38 PM
billib1954's Avatar
billib1954
Pretty simple. Remove outer primary cover, unbolt POS tensioner, throw away. Install a Hayden M6. Reinstall primary. Done, have a beer.
Old Sep 7, 2017 | 10:17 PM
FlaHeatWave's Avatar
FlaHeatWave
The OE Auto Tensioner on the '09 has been working fine, no issues whatsoever, for 59k miles so far...
The Chain has always been within specs when checked...
My trick is no engine braking until the drivetrain is up to / near operating temperature...
Old Sep 8, 2017 | 01:06 AM
0ldhippie's Avatar
0ldhippie
Just tack weld it to the adjustment ya want. 5/8"
Old Sep 8, 2017 | 06:33 AM
hellonewman
Thats an interesting idea except my thinking is that as the engine warms up the chain will get longer (just like exhaust systems grow in length with heat) and will allow the tensioner to tighten it even more vs a cold chain could be.
Old Sep 8, 2017 | 06:59 AM
lionsm13's Avatar
lionsm13
I replaced mine w/a Baker Bad Attitude manual adjuster.
