I have a 2011 HD Wide Glide and the cable broke at the clutch lever. I have 12in apes on it and have ordered the cable. How difficult will it be to install the new cable. The cable is apprx 69 to 70 inches. How difficult will it be for me to install this as this will be my first time?
Take a peek at your factory service manual and decide if YOU have the skills. Would be easy peasy for me but I don't know if you're capable. Many folks are not.
I have always had mechanics do my warranty work and since this is not covered I will give it a shot. I have replace the carb and rejetted it on my sporty when I had it. This doesn't look that to terribly bad. I know I will have to pull the exhaust pipes and I know that I have to be careful when I pull the cable and to pay very close attention on how it connects. I was hoping for more insight on the procedure from someone that has been down this road before.
Well...I dig what you're saying, it's not a tough job, but the play by play is in the manual. And you really ought have one before you turn a wrench...the World Wide Web ain't a substitute. I understand that they have doubled in price but you may be able to find one at the old price if you hustle.
There is one bit of 'insight' I can provide. To me, the toughest part of the job is getting the threads from the cable to the tranny cover started. If you're not careful, you'll cross thread one or the other...or both. I have acquaintance who did the 'both' part, and it got very expensive. But this is a guy without the skills for even this simple job!
Hardest part will be the exhaust, the rest is pretty simple. Will need a large snap ring pliers for the snap ring inside the side cover. Take a photo of the inside of the cover, before you take it apart, so you know how it goes back together again. Same thing with the cable routing. Also, lube the hell out of the cable with either cable lube (available at the dealer) or spray silicone you can get at Walmart for a few bucks. If its braided stainless cable, use the spray silicone. Most cables break due to poor maintenance and lack of lubrication.
I thank you all for the good information. The exhaust was easy for me; no problems there. I will do as Veekness said; "watch the threads and not cross them". It is the disconnecting that worries me. Will I have to pull that cover off or when I unscrew the old cable or will I be able to tell how it connects inside? Thanks again for the valuable info I have received.
The lever end is easy, the trans end is a bit more of a challenge. PM me and I will send you a link for a 2012 Touring manual. Not the same bike but I think the trans trap door cover is pretty much the same.
There are also lots of youtubes on this. You will lose some trans oil unless you want to lay the Wide Glide on its side. I did this once on my wife's old Low Rider.
For my old 2001 RKC I have the actual paper manual, and after 16 years it is falling apart, and is dirty and greasy. For my 2012 RGU I bought it in PDF format. Just Ollie at it on the computer and print out the section I need. Never gets dirty, greasy or falls apart!
