Full touring
Old Sep 15, 2017 | 11:07 AM
From_Behind's Avatar
From_Behind
Originally Posted by whyrzwaldo
I may not be updated with all the new fangled fun on the newer bikes........but isn't the keys just for access to your fuel door, saddlebags, and tourpak plus ignition lock?
I'd be more concerned with no fobs and a disabled security system! I'm assuming and HOPING your using the key to lock the ignition so it can't be rotated to start?
Getting that security system enabled and new fobs would be first on my list. A 2016 might look very tempting sitting there to someone who can start it without a fob!
A trip to the dealer is the best I think! Enjoy your new scoot!
Lots of us have bikes that don't even have security systems.
Old Sep 15, 2017 | 12:32 PM
DAVENRINO's Avatar
DAVENRINO
True, but if your bike came with it standard, wouldn't you want it to work?
The OP never did make it clear if it is enabled and just using PIN to start it. I am not sure what is involved to enable it but the dealer will have to connect their computer to the bike to register the FOB. My dealer didn't even charge for this and I believe the Key and FOB were only $85 for both (35/50).
Old Sep 15, 2017 | 01:16 PM
From_Behind
I personally wouldn't want anything to do with it - I'd probably have it removed.
I'm still just wondering what makes the OP think that he has security installed - he never said how he's starting the bike. If he's using the PIN each time, that sucks. Otherwise, he might just be assuming that he has security.
Old Sep 15, 2017 | 01:27 PM
Bone Doc's Avatar
Bone Doc
... The OP never did make it clear if it is enabled and just using PIN to start it...
... he never said how he's starting the bike...
The OP posted this
Originally Posted by Nicks HD
I just found an owners manual on ebay, I think the security system has been disabled so I can use the motorcycle
I had purchased the motorcycle from a business that is not a HD dealer
which gives the impression the security system, if he has one, is disabled.
It suggests that he just turns the ignition on and starts the bike.
Old Sep 15, 2017 | 01:42 PM
From_Behind
You're right, and I did see that. However, still questions. If the OP purchased the bike from a non-dealer, who disabled the security system? Does that require Digital Technician?
I looked in my service manual (newer Road King), and it appears that the FOB must be present to even completely remove the security module. So, did the business (seller) remove/disable it, and just throw the FOB away?
Old Sep 15, 2017 | 08:17 PM
DAVENRINO's Avatar
DAVENRINO
That seems a bit strange to me, but whatever floats your boat.
Of course it has security, unless someone removed it as it is standard equipment on a 2016 FLHTK.
Old Sep 15, 2017 | 08:35 PM
From_Behind
That seems a bit strange to me, but whatever floats your boat.Of course it has security, unless someone removed it as it is standard equipment on a 2016 FLHTK.
Eh, I just don't have any need for the security system. LOL.
But, that's good to know that it's standard on the bike in question. Thank you!
Old Sep 15, 2017 | 10:56 PM
kojak's Avatar
kojak
Giving up my 05 FLHRCI for a 16 FLHTK,
I am looking for information about my security system.
My bike came with just one key, no fob's and not much else.
I would like to change the Pin number, marry two gobs and activate the alarm system
Can someone let me know how to get this done please
Are you sure the fob is not stashed in one of the bags or tourpak somewhere? Its kind of bizarre to have a 2016 limited with a non-functioning security system. To reset the pin or to put the bike in transport mode you need the proximity fob. How are you starting the bike, using the pin to disable the alarm? Is the dash security light flashing when the bike is parked?
Old Sep 16, 2017 | 03:49 AM
From_Behind
I think he's gone, and we'll never know.
Old Sep 16, 2017 | 05:03 PM
grbrown's Avatar
grbrown
Red face
His bike should have two keys with fobs!
When you next buy a brand spanking shiney new bike I suspect you will be pleased to know it has a security system!
I suspect you're right!
