Widest Luggage Rack
Old Sep 20, 2017 | 01:43 PM
SnoRider's Avatar
SnoRider
Default Widest Luggage Rack
I am looking for the widest luggage rack I can find. The bag I rock is 20" wide. I see that the MoCo has a rack that expands but it runs about $350. Wondering if anyone can point me in the right direction for a less expensive option. Connect to 4 point.
Old Sep 20, 2017 | 02:41 PM
rcn1963's Avatar
rcn1963
This is the one I have. The spec says 14.5 inches wide so you would still have some overhang. But 3 inches on each side won't be enough to touch the saddle bags. That rack and a little bungie type cargo net thing and I can carry a wide variety of stuff. It's held a half case of beer more than a few times.
https://www.harley-davidson.com/stor...le-two-up-rack
Old Sep 20, 2017 | 05:50 PM
SnoRider's Avatar
SnoRider
Thanks RCN, that's the one I have too. Nice rack but causes my bag to sag.
Old Sep 20, 2017 | 06:51 PM
giacomo56's Avatar
giacomo56
Line the bottom of your bag with a nice stiff piece of scrap wood paneling....it's thin, it wont sag and is strong....save your money for a new rack......
Old Sep 20, 2017 | 08:35 PM
SnoRider's Avatar
SnoRider
I used 1/4" mdf. You have to put the sheet under the bag rather than in the bag. Because the sagging is caused when I tighten the straps to the rack rather than because of weight. If that makes sense. Tighten down the straps and because the footprint of the rack is so small it deforms the bottom of the bag.
Old Sep 20, 2017 | 08:41 PM
Check6's Avatar
Check6
Got one of those expandable racks. Used it on my Road King once. Own an Ultra Limited now so have no use for the rack. It's yours for $200 if you add $20 for shipping. Here's a pic of it on the bike before I traded it. PM me if interested.
Old Sep 20, 2017 | 08:48 PM
Ex-Leftcoaster's Avatar
Ex-Leftcoaster
A buddy has the HD Stealth rack on his King. He bolted a larger sheet of plywood (then switched to a metal plate) on the rack with holes on the ends for tie downs. Could be worth a try if you don't want to go permanent.
He uses a good size duffle bag and other soft luggage on it for some of our vacation trips.
Old Sep 20, 2017 | 10:15 PM
SnoRider's Avatar
SnoRider
i could be down with that. Let me check with the boss!
Old Sep 20, 2017 | 11:30 PM
SnoRider's Avatar
SnoRider
I wonder if I could get one of those racks that go on the tourpak and mount it directly to a tourpak mount. Does anyone know the dimensions of the bolts on the tourpak lid rack?
Old Sep 21, 2017 | 04:23 AM
grbrown's Avatar
grbrown
Wink
Yup! I have an Air Wing rack, although I suspect the mounting points for all tourpak racks are the same. Mounting holes are 8" apart fore and aft, 12" side-to-side. The rack is just over 20" overall width. A new one will cost about the same as the rack Check6 offered....
