Cfr slip ons
Old Oct 1, 2017 | 07:56 PM
2014sportsteriron883's Avatar
Default Cfr slip ons
im looking into putting cfr slip on this winter I currently have 3.5 inch true dual rineharts with se 204 cams
anyone have experience with this kind of setup or should I look at different cams with thes pipes I hear they loose a bit of low end?
Old Oct 1, 2017 | 08:14 PM
Glide83's Avatar
Glide83
6th Gear
They rid you of very useable torque in the rpm range where you ride the most. Even worse if you have true duals. If loud is the goal it's no problem. If you're going for Performance, they are literally the very last exhaust that would be on my list.
A friend of mine has them and I rode the bike. It was asleep until 3500rpm.
Old Oct 1, 2017 | 08:24 PM
Dynaglide92's Avatar
Dynaglide92
The se204 is a great all around cam that won't be fully utilized with the cfrs. The 204 shines where the cfrs are known to dip plus they drone bad couldn't bear them after an hour
Old Oct 2, 2017 | 02:22 AM
ChromeJunkie's Avatar
ChromeJunkie
CFRs were on my 2013 Limited when I bought it. I'm definitely not impressed with them and plan on changing them as soon as I figure out what I want
Old Oct 2, 2017 | 04:23 AM
good to know thanks for the info I do like the 204 cams but I also like the sound of the cfr so maybe I’ll just keep my rineharts and save some disappointment if the performance goes down hill
Old Oct 2, 2017 | 04:49 AM
decencyxdefied's Avatar
decencyxdefied
The rh's are definitely a better pipe to me..they have an amazing sound and don't lose the power..the cfr's are good in their own right too but it's more of an aquired taste I think
Old Oct 2, 2017 | 05:10 AM
i just like the sound of them and I thought if some guys maybe had better suggestions to a different cam to run with them other than the 204 that will sound and perform nicely on a otherwise stock 96 tc I’d think about a cam swap as well only due to the fact I have to get it re tuned and I’m pulling all the covers off to get them powder coated anyways
Old Oct 2, 2017 | 05:53 AM
Tn.Heritage's Avatar
Tn.Heritage
I've got a good friend of mine said and did the same thing your wanting to do, it hurt his bottom end with a lot of throttle lag and now he's not overly happy with the sound either. He say's they have a drone at cruise that's really annoying and thinking of taking them off.
So you had several people tell you the bad of the cfr's, so it's up to you now but if you bolt them on you will probably be one of many that say's, I think they didn't hurt my bike at all, in fact I think it has more power now. LOL
Just kidding but I's seriously think of going a different direction, good luck.
Old Oct 2, 2017 | 05:55 AM
thank you for your input the more I read the more it makes me just leave it the way it is now and spend the money on something else
Old Oct 4, 2017 | 12:20 AM
Melroy's Avatar
Melroy
sound great....the performance and ability to tune them is another story
