Bearings - How often?
Old Oct 7, 2017 | 10:30 AM
F150HD's Avatar
F150HD
what is the best set of replacement bearings? Talking 08-13 Touring here.
Unless newer models use the same bearings.
Georges tool or Pit Posse tool sound like a go to tool for this? (read that in another thread)
Old Oct 7, 2017 | 10:53 AM
Sc0-'s Avatar
Sc0-
I check my bearings at each tire change. SKF 6205 2RSJEM bearings, not including the HD ABS bearings. I​​​​​​I think i have the Pit Posse bearing tools and they are working well enough
Old Oct 7, 2017 | 06:44 PM
big- mike's Avatar
big- mike
Pit boss tool worked for me I did mine on my 2010 ultra at 43000 just because not a bad job couple hours and you done. The old bearings looked ok but I'm the second owner and didn't know if they had been changed before. You should just go ahead and do it if you don't you'll think about it every time you ride that's what happened to me so I changed them for the peace of mind
Old Oct 7, 2017 | 07:16 PM
RevBlk's Avatar
RevBlk
Originals in my 07 but they're the old style. I check them every time it's on the lift for a service and inspect them at every tire change.
Old Oct 7, 2017 | 08:22 PM
leon anthony's Avatar
leon anthony
I changed my wheel bearing on my 2008 ultra at 100,000 there was nothing wrong with them just eased my mind
Old Oct 7, 2017 | 08:34 PM
IrishHogtrotter's Avatar
IrishHogtrotter
Once I got shot of the Harley oe replacements for the originals that crapped out at 5k for the front and 8k for the rear, the Swedish ones seem to be doing well now for 30k mile.
But I check for roughness every tyre change
Old Oct 7, 2017 | 08:37 PM
duoglider's Avatar
duoglider
45+ years of riding motorcycles and I've never needed to replace a bearing.
Internet is full of smoke and mirrors.
Old Oct 8, 2017 | 12:21 PM
lt1-xjs's Avatar
lt1-xjs
Bearing issues were basically non existent until 2008 when they changed the size of the bearings.
Old Oct 8, 2017 | 07:55 PM
Porky11's Avatar
Porky11
Default Bearings
I just changed mine in the front wheel, used the puller from George's Garage and it was a piece of cake!! I changed them at about 50000 miles for a set of stock bearings, they weren't bad but the new ones rolled a lot better. If you have the right tools it is REALLY EASY. Good luck
Old Oct 8, 2017 | 09:22 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
The proper amount and type of grease, along with really good seals, are key. If you replace a good set that meets the above criteria, and replace them with some that don't, then that early replace would be a bad move.
Still riding on the originals here, too.
junkyardscrounger
Aug 18, 2019 04:56 PM
JakeUSAF
2014-2024 Touring Models
Oct 5, 2017 02:52 PM
Porky11
Jul 14, 2017 06:35 AM
falconbrother
EVO
13
May 3, 2014 05:58 PM
Shaved Ice
Jul 10, 2013 12:22 AM
