Shuts down
Old Oct 27, 2017 | 02:07 PM
Martiniz1's Avatar
Martiniz1
5th Gear
Check ignition switch wire harness. i have a similar problem couple years ago in my 07 flhtcui
in my case the center wire on the harness attached to the ing. switch, was loose and come out of the plug socket when turning.
Remove harness from switch and make sure all wires are clean and all the way into the plug
Old Oct 27, 2017 | 02:17 PM
Martiniz1's Avatar
Martiniz1
5th Gear
Not my image, just for reference.
Old Oct 27, 2017 | 04:13 PM
03mg88flh's Avatar
03mg88flh
00copglide...You were spot on dude...Found the short in the green wire coming off the wire harness....Funny part is that it broke within the sheath itself..it was not visible or cut and dry..Had to run my fingers along each wire one at a time until I found that there was a flat spot in the wire and that's where it was broken. Apparently when ever the bars were turned to the right the wire would lose contact and when I would go past that "sweet" spot it would make contact and I would have power again...To say the least this was one for the books, and I have been riding for 40 years plus, and have never run across this type of problem...All I can say is that never trust what you see and always feel the wires one by one....00copglide.. thanks for putting me on the right path to getting this problem fixed, you Sir were spot on...Thanks a bunch!!! It is great to have my therapy back again...Two thumbs up for you......This is what it's about....Thanks man!!
Old Oct 27, 2017 | 06:32 PM
nutsandbolts5212's Avatar
nutsandbolts5212
Great troubleshooting, gotta love that!!
Old Oct 27, 2017 | 08:11 PM
00copglide's Avatar
00copglide
Glad to hear it!! I had that same problem a couple years ago...had to run fingers along insulation...glad I could help out....they are notorious for that!!
Old Oct 27, 2017 | 08:21 PM
FXDXTSport's Avatar
FXDXTSport
Gotta love a happy ending
Old Oct 28, 2017 | 01:12 AM
03mg88flh's Avatar
03mg88flh
Want to thank all who replied to this thread, all the ideas and suggestions were appreciated...Be safe all..
murph
Nov 1, 2017 11:03 AM
AHFD45
Aug 23, 2017 09:27 AM
GreyBob
May 20, 2017 05:38 PM
marvincbr
Jan 2, 2012 02:00 PM
k23rd
Jun 1, 2005 04:15 PM
