Tire concerns.
Old Oct 17, 2017 | 10:01 PM
Butters514's Avatar
Butters514
Stage II
Default Tire concerns.
Hey y'all so I ride a 2007 Road Glide. It currently has a 140/90H16 (MU85B16) on it. I found an aggressive 140/70H16 I'd like to put on her. What besides a few inches in height will it change?
Old Oct 17, 2017 | 10:11 PM
perki48's Avatar
perki48
Speedometer accuracy.
Old Oct 17, 2017 | 11:49 PM
TriGeezer's Avatar
TriGeezer
Welcome..
Yep, it'll change speedometer accuracy, and depending upon what you mean by "aggressive" possibly handling.
Old Oct 18, 2017 | 02:05 AM
critter85's Avatar
critter85
Speedometer accuracy, not sure if a dealer can change and make it correct, but would be worth ask if it matters.
Old Oct 18, 2017 | 05:37 AM
Butters514's Avatar
Butters514
Stage II
I mean the tire has a deeper tread pattern then most. I had the same tire on a different bike and loved it. I'll call the stealership and ask them if they can correct the Speedo. Thanks for the help so far.
Old Oct 18, 2017 | 05:45 AM
Notgrownup's Avatar
Notgrownup
Most tires I’ve run on my 07 have 11/32” what tire has more than that?
Old Oct 18, 2017 | 05:53 AM
nevets61's Avatar
nevets61
You speed in 6th gear will be slower for the same RPM however being an 07 that's not a bad thing since the 07's were geared a bit high... might improve your ride-ability overall, but your speed will drop about 20% if I did the math right, 75 on ODO will be 60 actual.
Old Oct 18, 2017 | 11:03 AM
perki48's Avatar
perki48
Re-figure your math. 25.92 inches tall verses 23.8 inches is closer to 10% than 20%.
Old Oct 18, 2017 | 12:24 PM
Notgrownup's Avatar
Notgrownup
This is just me but I would rather use the size my bike needs... Make sure you also adjust your headlight.
Old Oct 18, 2017 | 12:44 PM
nevets61's Avatar
nevets61
Thanks perki48, in the wee hours of the morning the 20% seemed to large, I must have hit a wrong digit when I crunched the numbers.. So yes its not quite a 10% error... 75 on OD is 68 actual.
