Best sounding cams
Old Oct 31, 2017 | 07:14 AM
SBates08's Avatar
SBates08
I think you'd be money ahead to have your heads worked versus going up to a 103 without headwork.
Old Oct 31, 2017 | 08:58 AM
QNman's Avatar
QNman
Originally Posted by 2014sportsteriron883
Maybe I’ll rephrase this
what cam will out perform the 204’s
im looking at
t man 555 tourqester
Dragos 565
woods 555
looking for low end all the way up and I’d like to keep it a 96 for now so I’d like a cam I can expand with
A buddy of mine has the Woods in his 96. From 3,000 RPM up, it is a beast; He dynoed out near 100 HP and something close to 110 ft-lbs. However, below 3,000 RPM, it wasn't much better than stock. That was with a 2-into-1 exhaust and a full dyno tune.
YMMV.
Old Oct 31, 2017 | 11:29 AM
Tn.Heritage's Avatar
Tn.Heritage
204's or Woods 777's sound good.
Old Oct 31, 2017 | 05:15 PM
bklynbob's Avatar
bklynbob
Do both.....
Old Oct 31, 2017 | 05:25 PM
2014sportsteriron883's Avatar
Originally Posted by bklynbob
Do both.....
i am I went to see a guy today he said mild head work and 103 and it will scream so just need to get it all pulled apart over the winter
Old Oct 31, 2017 | 08:35 PM
6 gun's Avatar
6 gun
If you are going to bore it to a 103 then get some SE pistons that will push your compression up to 10.5:1 and use some SE 259e cams you will love it.
Old Nov 1, 2017 | 02:00 PM
harley#1's Avatar
harley#1
when mine was a 96 i put a stage 1 and a S&S 551 cam in and had it dynod. bike worked great, lots of bottom end and pulled good in 5 or 6 gear on a roll on. you won't be disappointed.
Old Nov 1, 2017 | 03:55 PM
So now that I have decided on what route I’m going I will have compression release ports drilled into the heads and plug them.... will I need to install releases if I keep stock head gaskets with the 103? I figured may as well tap the hole invade I do end up needing them
i know people say the 204 don’t bump up cranking pressure and some say they do
Old Nov 2, 2017 | 10:59 AM
OldPhat's Avatar
OldPhat
The SE-211 is still a drop in cam similar to the 204s but with more duration.
211 Cams will work in a 103 with 10:0.1 or 10:5.1 compression, you should add compression releases to this combo.
John
Old Nov 2, 2017 | 11:38 AM
Donnylee's Avatar
Donnylee
211s worked well in my 2008 96. And sound wicked. Nice mid upper power.
