The auxiliary headlight has stopped working
Old Nov 9, 2017 | 07:24 PM
py4afl's Avatar
py4afl
Stage II
Default The auxiliary headlight has stopped working
I already tested the bulbs, and the switch. The warning lamp on the switch lights, but the panel does not. There are no broken fuses.
Old Nov 9, 2017 | 07:45 PM
giacomo56's Avatar
giacomo56
Jeez....the amount of informatio you posted to troubleshoot "your headlight" is overwelming.....
What type? Tungsten or LED?
Is it one or both?
Did you switch the headlights to see if it's the "Bulb" portion that is the culprit?
Did you make sure the plugs arefully engaged/tight?
Just a few questions that would help us in helping you.....
Old Nov 9, 2017 | 08:25 PM
py4afl's Avatar
py4afl
Stage II
Hello Giacomo, thank's to answer me.
What type? LED
Is it one or both? Both
Did you switch the headlights to see if it's the "Bulb" portion that is the culprit? No, LED original.
Did you make sure the plugs arefully engaged/tight? Yes I checked.
Old Nov 9, 2017 | 09:13 PM
giacomo56's Avatar
giacomo56
I am thinking that one of the wires has come loose on one of the connectors...make sure they are seated correctly.....two wires running to the lights a power and a ground....make sure they are firmly seated...
If you can bypass the switch...it might be bad and make sure the connector is seated into the switch...
Old Nov 9, 2017 | 09:17 PM
LoneRiderFLH's Avatar
LoneRiderFLH
Is your headlight on low beam?
normannewguy
May 14, 2019 08:21 AM
DaSham58
Electrical/Lighting/Alarm
Jul 8, 2013 07:47 AM
ttudesperado
Jun 1, 2011 12:41 PM
BB4xl
EVO
Aug 13, 2010 11:04 PM
chidiver
Mar 2, 2010 06:04 PM
