Change handlebars
Old Nov 14, 2017 | 05:54 PM
Bulee's Avatar
Bulee
Default Change handlebars
Hello! I have an 07 road glide with cruise control and I want to change the stock handlebars for a 18" ones. I have change a few handlebars in the past from a dyna and sportster and have no problem with that, but I have never changed any bike with cruise control, it is not an electronic throttle so the question is, does the cruise control works with cables? or just normal extension of the wiring (like a turn signal) will be necessary?
Old Nov 14, 2017 | 06:04 PM
beanoboy's Avatar
beanoboy
On my 06 RG it's part of the wiring harness in the throttle side switches. I have to tell you that it's not a half hour job changing bars on these models. I recommend you check out 'you tube' which will show you the sequence on the RG, they only show newer models with the throttle by wire but it gives you an idea of what to do...b.
Old Nov 14, 2017 | 06:31 PM
Bulee's Avatar
Bulee
Ok, one of my concerns was that I've seen the modules and they look like they have a trim of throttle cable, so I wonder if I am going to need replacement/extension for that wire from the module..
Old Nov 15, 2017 | 05:09 AM
grbrown's Avatar
grbrown
Red face
Just be aware that we have a steady trickle of members who introduce electrical gremlins, as a result of doing their own wiring extensions, especially when wiring inside the handlebars. So take great care as you work!
Old Nov 15, 2017 | 06:12 AM
Architect's Avatar
Architect
Just wires, extend them as needed with the rest of the wires. Yes a PITA on a Roadie, but worth it for comfort, my opinion. I did 12" on my '05, all the wires reached and I was much more comfortable.
Old Nov 15, 2017 | 07:02 AM
decencyxdefied's Avatar
decencyxdefied
definitely worth is for comfort, as long as you splice the wires in an offset pattern and get good connections you will be good to go
Old Nov 15, 2017 | 09:37 AM
beanoboy's Avatar
beanoboy
If you remove the outer fairing you can pick up approx. 6" of slack on the wiring by re-routing the existing wires. I don't know if this would be enough for 18" bars but it was more than enough for my 14" ones...b.
Old Nov 15, 2017 | 10:33 AM
Bulee's Avatar
Bulee
Thanks!!! Will do!
Bulee's Avatar
Bulee
I'll check it and share the result! Thanks!
Bulee
Nov 15, 2017 11:14 AM
matttaylor817
Jul 7, 2015 04:06 PM
jpooch00
Jul 19, 2012 09:35 PM
honda236
Jun 29, 2010 11:02 PM
honda236
Jun 29, 2010 06:01 PM
