Best amp?
Old May 20, 2018 | 08:05 PM
5280Ruffian's Avatar
5280Ruffian
Originally Posted by pingman68
I have an Aquatic av and Infinity Kappa’s as well, and I installed a Soundstream amp that I got off Amazon for around $80. It rocks! Most of the time I’m only running it at about 12 to 14 on the volume level.
How did you mount it?
Old May 20, 2018 | 09:33 PM
Fireball Jack's Avatar
Fireball Jack
Originally Posted by Zerk
Do they all effect FM reception?
I am looking for something under $300 for front and rear speakers. Hogtunes, which are 2 ohm. And this is the extent of my knowledge. Just want something easy.
Dump the hog tunes. Kappas in the front and polk mm652 in the tour pak. The cheaper amps dont kill the FM in the rushmores. If you want to stick to the 300 budget you will be very limited.
Old May 20, 2018 | 09:42 PM
Zerk's Avatar
Zerk
Maybe it is out of my budget. I was thinking about hogtunes amp for $400.
I am not going to start chasing speakers. I am not that into it. I put them in cause everyone liked them at the time. Not going to throw another set of speakers in for the same reason.
Also not sure I would bother with rear speakers. Due to Harley vanity and cosmetics, they are in a crappy spot.
Old May 20, 2018 | 09:55 PM
HOGILAC's Avatar
HOGILAC
Default Amp
JL Audio..., hands down. This may be more than u need so go with the 400/4. Clean Sound. I have it on 2 Hertz 6.5 and 4 Rockford 6x9. Mounts on deck. I have the same radio.
Amazon Amazon
Old May 20, 2018 | 10:01 PM
Zerk's Avatar
Zerk
Also is a better radio, better than amp? I got an 07. Maybe not for me either.
I hate my fatcat that burns holes in my jeans, maybe I need to go back to a quiter pipe.
Old Jul 6, 2018 | 11:31 AM
Bootsie's Avatar
Bootsie
If you plan on running 4 speakers this is a great little amp. Probably will kill your FM.
https://www.amazon.com/Soundstream-P.../dp/B00VH40878
Did you mount that in your fairing? Having a hell of time trying to figure out how to mount it or where in the fairing
Old Jul 6, 2018 | 11:52 AM
Fireball Jack
I set it on the head unit. It is tight you have to slide it under the wire bundles and back as far as you can. It has been there for over 10k.
Old Jul 6, 2018 | 08:14 PM
Jetblack3's Avatar
Jetblack3
Originally Posted by JetRanger
Greetings,
I just installed an Aquatic AV radio on my 09 Ultra, paired with Infinity Kappa's...... I would like to install an amp with out breaking the bank.
Suggestions?
Thanks,
Jet
Move over into the audio forum and they will set you straight, days worth of reading. Just tell them what you have and what you want to accomplish and they will guide you.
Old Feb 18, 2023 | 04:50 PM
Cool Poppa's Avatar
Cool Poppa
Guys don't go cheap on your amp because amps are not the same. Stick with brand names like Focal Sport, Sound Digital and Diamond all good for motorcycle audio high end. Stay away from the low-end stuff.. Make no since to put a $50.00 amp in $30,000 motorcycle
Old Feb 18, 2023 | 04:59 PM
YZR's Avatar
YZR
Bluetooth earbuds are your friend.
