Best amp?
Old Nov 24, 2017 | 06:52 PM
JetRanger's Avatar
JetRanger
Default Best amp?
Greetings,
I just installed an Aquatic AV radio on my 09 Ultra, paired with Infinity Kappa's...... I would like to install an amp with out breaking the bank.
Suggestions?
Thanks,
Jet
Old Nov 24, 2017 | 07:20 PM
pingman68's Avatar
pingman68
I have an Aquatic av and Infinity Kappa’s as well, and I installed a Soundstream amp that I got off Amazon for around $80. It rocks! Most of the time I’m only running it at about 12 to 14 on the volume level.
Old Nov 24, 2017 | 10:06 PM
silverglide2010's Avatar
silverglide2010
I have the Soundsteam amp also. Great amp.
Old Nov 25, 2017 | 04:43 AM
UltraSteveUSAF's Avatar
UltraSteveUSAF
Which amp is that exactly? The only 1 I see on Amazon in that price range is 13 X 8 X 2, is that the size your running?
Old Nov 25, 2017 | 07:32 AM
Roadie13's Avatar
Roadie13
The soundstream and Cerwin Vega B52 and B54 are both good budget choices for 2 ohm speakers like the kappas. Not the best amp when you start talking about higher end equipment, but will work well in that application and both are tried/true entry level performers. If you decide to move up to better 4 ohm speakers later will need a better amp to drive them.
Old Nov 25, 2017 | 07:55 AM
pingman68's Avatar
pingman68
This is the one I have, looks like the price went up little bit since earlier in the year.
Amazon Amazon
Old Nov 25, 2017 | 08:56 AM
Fireball Jack's Avatar
Fireball Jack
If you plan on running 4 speakers this is a great little amp. Probably will kill your FM.
Amazon Amazon
Old May 20, 2018 | 10:53 AM
Zerk's Avatar
Zerk
https://www.amazon.com/Soundstream-P.../dp/B00VH40878
Do they all effect FM reception?
I am looking for something under $300 for front and rear speakers. Hogtunes, which are 2 ohm. And this is the extent of my knowledge. Just want something easy.
Old May 20, 2018 | 11:29 AM
Fireball Jack
It is hit and miss. I get FM but the sound isn't great. Depends more on distance from the towers I believe. I have an IPOD and stream music from my phone. FM in Seattle sux to much talking and commercials.
Old May 20, 2018 | 11:46 AM
Zerk's Avatar
Zerk
Do all amps do this or just cheaper one? I don't want to give up FM.
