Front Brake lever?
Old Dec 8, 2017 | 12:50 PM
Frozen Excursion's Avatar
Frozen Excursion
I had the same issue, my bikes been at the dealer for over 1 month waiting on an ABS module. Luckily I have the extended service plan.
Old Dec 8, 2017 | 02:21 PM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by m50
Sorry been out of the loop for a while. Is this something I can fix myself or is this one of those things that has to go back to dealer?
Thanks RB
Get yourself some non ABS brake lines and a piece of black tape for the ABS light. OR, pay 900.00 to 1300.00 dollars for another Chinese ABS HCU made by BWI (Harley's supplier). Worst design in ABS history.
Old Dec 8, 2017 | 02:25 PM
Campy Roadie
Originally Posted by SBates08
If mine ever goes out I'm just gonna bypass the damn thing.
Agreed. Why pay all that money for another Chinese part that's no different than the one that failed?
Here's the company that made them.
https://en.wikipedia.org/wiki/BeijingWest_Industries
Old Dec 8, 2017 | 03:05 PM
SBates08's Avatar
SBates08
My thoughts exactly. My Uncle took his 09 EG in for a failed unit. After it sat at the dealer for a month waiting on the part he just decided to trade for a new bike. Bike was still sitting in the shop 6 months later waiting on that part. This wasn't a warranty replacement either. It was coming out of his own pocket. From my understanding, they're having to replace so many of them that they can't keep them in stock.
Old Dec 8, 2017 | 09:06 PM
wibiker's Avatar
wibiker
Here's what it cost me to have my 09 FLHTC repaired. Looks like one part is Delphi, assembled in Mexico.
Attached Thumbnails Front Brake lever?-dscn2362.jpg   Front Brake lever?-dscn2361.jpg
Old Dec 8, 2017 | 09:35 PM
CSMHOG's Avatar
CSMHOG
You paid almost $600 just for tires?! You guys need to start shopping around or visit your Indy’s. $600 for tires? I can get American Elites for $320 and they’re better tires than OEM. As far as the HCU goes, go to board tracker, buy the parts and do the repair yourself. Once you’re done take it to the dealer to confirm the bleed and then keep them flushed every time you change your brake pads or at least once every two years.
If you think owning a bike is cheap, you’re wrong and I don’t care what brand you have.
Old Dec 9, 2017 | 04:49 AM
Campy Roadie
BWI is Delphi Chasis/Brake. Home base is in Beijing China and they have plants in other countries, including Mexico. Here is their website.
http://www.bwigroup.com/
As with most things from China, the Harley ABS system leaves a lot to be desired. Specifically, it's the ONLY ABS system on the planet that causes COMPLETE brake failure when the ABS unit fails. All others have full residual braking capacity sans the ABS function. In my opinion, that's borderline criminal.
Old Dec 9, 2017 | 08:10 AM
m50's Avatar
m50
I do need to make sure that the HCU is locked up but from all the talk on here it sure sounds like it.
I hate to do away with the ABS because that is the major reason that I traded for this bike. I am old and I don't react as quick as I once did!
I will try to report back. Thanks RB
Old Dec 9, 2017 | 08:17 AM
Campy Roadie
All you have to do is squeeze or depress the pedal or lever that's frozen. While holding it, break the banjo bolt loose from the corresponding line on the HCU. If the lever or pedal moves after fluid starts to seep out; there's your sign.
I'm sure you know, but clean up that fluid asap.
Old Dec 9, 2017 | 10:36 AM
wibiker's Avatar
wibiker
If everyone that has this ABS problem reports to NHTSA at safecar.gov they might make the mo-co do something to help the owners get a safe ABS system.
