2008 EGC wheel help
Old Dec 14, 2017 | 07:59 PM
stroker87's Avatar
stroker87
Default 2008 EGC wheel help
so as some of you know i just picked up new to me a 08 EGC
i love to white wall tires and spoke wheels mine has mags and black wall's so im looking for some rims so when i get tires i can have them mounted
what size axle did the 2008 have?
are the wheels the same and just different bearings?
Old Dec 14, 2017 | 08:19 PM
caulk04's Avatar
caulk04
25mm
Newer wheels swap right in. Just make sure you use the right bearing (abs or non)
I have an 18" airstrike on my 08 standard.
Old Dec 14, 2017 | 08:35 PM
stroker87's Avatar
stroker87
im just looking to stick with 16" wheels
but cant seam to find out info on bearings and rims
Old Dec 14, 2017 | 08:39 PM
1957buick's Avatar
1957buick
look up the bearings and see what years are the same , should help
Old Dec 15, 2017 | 05:10 AM
grbrown's Avatar
grbrown
Lightbulb
Caulk just told you about the bearings! For an easy life you should look out for a set of '08 wheels from an RK or other touring bike with spoked wheels. If you feel able to swap bearings you can look for suitable wheels from 2000-2008.
Old Dec 15, 2017 | 07:58 AM
stroker87's Avatar
stroker87
awesome!
thanks every one!
Old Dec 15, 2017 | 08:26 AM
grbrown's Avatar
grbrown
If you buy the earlier wheels they have 1" ID bearings, but the OD is the same as the 25mm ones. You will however need a different bearing spacer to go between the bearings, as the 25mm are narrower than the 1".
Old Dec 15, 2017 | 09:52 AM
stroker87's Avatar
stroker87
would i be able just to take the spacers out of my current wheels?
Old Dec 15, 2017 | 10:07 AM
grbrown's Avatar
grbrown
Yes, although doing so may spoil your bearings, due to applying a side load on them when removing them. Personally I would use new bearings.
Old Dec 15, 2017 | 11:49 AM
stroker87's Avatar
stroker87
i'd be getting new bearings anyway even if i keep my current wheels
