What is needed to by pass ABS
Old Dec 15, 2017 | 07:28 AM
ORradtech's Avatar
ORradtech
Originally Posted by Scudda
There are thousands of bikes it works fine on....also think about how many cars it is on and working over the years....you can't live your life on "What If's"
The difference being when ABS fails on a car it defaults to non ABS regular braking.
When HD's ABS fails the accuator (lever or pedal) locks up leaving you with little to no control. And since HD is failing to acknowledge a problem and blaming the consumer and charging upwards of $1200 to put the same questionable parts in it's not hard to understand why people want to bypass the system.
Old Dec 15, 2017 | 07:43 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by Back-n-Black
Only idiots bypass safety....
A safety system that completely eliminates the brakes when it fails is of questionable safety.
But, that's just me.
Old Dec 15, 2017 | 09:30 AM
hattitude's Avatar
hattitude
The problem with this statement, is that "idiots" and "safety" are highly subjective....
Old Dec 15, 2017 | 09:40 AM
Oko's Avatar
Oko
So, if you bypass the factory ABS, & get into an accident. The insurance company detects that you’ve bypassed it, well.....
Good luck with that.
Me, I’d get it fixed.
Old Dec 15, 2017 | 09:42 AM
grbrown's Avatar
grbrown
Thumbs up
Very true! I've only ever owned one ABS bike, in over 50 years and don't own one at all at present. Frankly I don't feel any less safe on any of my three current bikes....
Old Dec 15, 2017 | 10:16 AM
SBates08's Avatar
SBates08
Ima call bullshit on this one.
Old Dec 15, 2017 | 10:35 AM
ORradtech's Avatar
ORradtech
Yeah, I'm going with bs on this too.
Too many bikes built with ABS as optional equipment to make that argument.
Bypass just needs done in competent manner.
Old Dec 15, 2017 | 10:52 AM
KumaRide's Avatar
KumaRide
Originally Posted by dowhat
A month ago I picked up a 08 Road Glide and the front brake is hard to pull now, so with everything I have read, it points to the ABS unit. I would like to by pass the system with a new front brake line.
I know I need the brake line for a non ABS bike, would I have to change out the front wheel bearing also.
Thanks for any help, been reading about all the failed systems and have not found a lot on by passing it.
Please report to NHTSA. ABS failures are almost becoming a regular event on this site. Think of the 10's of thousands of riders that are not on this forum.
I'd fix it, myself though. Dont care if "you" dont.
No need to change out wheel bearings, just leave the sensor installed because that is also a type of spacer.
It is possible to bypass only the front brake portion per the link sbates provided. The abs diags only test electrical, not physical abs solenoid lockup. In other words, go for a ride without your front brake and the abs diags will pass - very pathetic diags! Anyway, bypass front abs module circuit and you will still have rear abs. I'd rather have rear then front anyway. And rear abs is better then no abs imho.
Old Dec 15, 2017 | 12:04 PM
Oko's Avatar
Oko
So your an insurance agent? Perhaps a personal injury lawyer?
Because I actually called my agent & asked before I posted. He said they could look at all modifications to see if it was a contributing factor to a crash. Removal of any OEM safety device, car or bike, could cause denial of a claim. Either for vehicle damages or medical claims. He said it would more likely surface in a large medical claim.
So yeah, I stand by my post.
Old Dec 15, 2017 | 01:05 PM
Duracell's Avatar
Duracell
Me three. I have an 08 touring bike. The ABS was optional, I don't have it on my bike. As many know the first years systems are prone to fail in very unsafe ways. I don't blame the OP for his decision to remove it.
