Rocker covers
Old Dec 24, 2017 | 01:34 PM
2014sportsteriron883's Avatar
Default Rocker covers
So I pulled my 08 sg apart today to send the heads out to have ACR ports machined in and I noticed that the rocker covers do not have a square hole in the center to allow me to remove the ACR without taking the rocker covers and lower base off.
do the wires just get tucked under the rocker boxes or do I need a different style rocker box setup with a hole up through the center?
Old Dec 24, 2017 | 02:19 PM
skydude426's Avatar
skydude426
The wires get tucked under the rocker boxes, routed towards the throttle body in the center of the engine. You have to remove the rocker boxes to gain access to the ACR's.
Sent from my iPad using IB AutoGroup
Old Dec 24, 2017 | 02:23 PM
BB59's Avatar
BB59
The ACR wiring harness runs under the rocker housing
a little slow typing ... beat me to the punch
Old Dec 24, 2017 | 02:32 PM
Thanks guys!!
Old Dec 24, 2017 | 10:30 PM
IKnowNot's Avatar
IKnowNot
I do not know what type air cleaner you have, but when I added the ACRs I also added the Screamin' Eagle Ventilator Elite Air Cleaner Kit whcih came with a clip for the ACR wires (because the Induction Module Bracket gets removed, thus the below clip would not work for me.)
If using the stock A/C with the stock Induction Module Bracket, maybe the ACR Connector Clip (part number 10398) would work for you??
(it is about 2 bucks, and meant to hold the wires out of the way.)
Old Dec 25, 2017 | 01:40 PM
I’m running an open air cleaner and I’ll look into that clipThanks
AJSHOVEL
Ironhead
Jul 9, 2013 11:29 AM
Mithion
Feb 23, 2013 08:13 PM
mtnlvr
EVO
Apr 7, 2009 02:48 PM
Redd
Mar 30, 2008 03:49 PM
Redd
All Other Models
Mar 30, 2008 03:45 PM
