Clutch cables
Old Dec 30, 2017 | 12:17 PM
Softy 103's Avatar
Softy 103
Default Clutch cables
Put 10" yaffe monkey bars on my 2012 Street glide used a clutch cable from Drag Specialties. Every since doing this my clutch pulls a lot harder than it used to, is there a better or easier pulling cable than the one I have?
Old Dec 30, 2017 | 12:23 PM
fordhd2005's Avatar
fordhd2005
Are you sure it's the cable causing the issue and not how it's routed? If it's binding in the least at the lever it's going to be harder to pull especially if it's coming out at the lever then making a 90 degree turn down to route into the fairing.
Old Dec 30, 2017 | 12:32 PM
Softy 103's Avatar
Softy 103
It is routed to the hole in the fairing, don't know how else to do it.
Old Dec 30, 2017 | 01:51 PM
fordhd2005's Avatar
fordhd2005
All i’m saying is, if the cable is bending before it goes through the fairing, it will be harder to pull because it’s binding. I have 12” bars, not monkey bars though, but see what I mean? The cable flows...
Old Dec 30, 2017 | 06:23 PM
Softy 103's Avatar
Softy 103
Ya mine have a little more bend than that, talked to my tech today he said drag cables don't work with bends near as good as Barnett cables and my trans is leaking where the cable goes in anyway, so gonna try a Barnett cable
Old Dec 30, 2017 | 10:47 PM
SBates08's Avatar
SBates08
I've tried a couple Drag Specialties clutch cables on my bike with 14" apes and they binded pretty badly. I lube the latest one pretty regular to help the pull on it till I can change it to a better cable.
Briguy1
Aug 13, 2022 05:31 PM
gnalen
Jun 19, 2018 04:04 PM
keith t
Apr 18, 2016 07:50 AM
ocezam
Oct 26, 2013 08:46 AM
lp
Apr 11, 2007 12:50 AM
