Sunpie LED headlight fitment
Old Jan 15, 2018 | 06:08 PM
lefty33's Avatar
lefty33
Originally Posted by deadbroke
So you trimmed out the bucket and now the lamp fits flush like the O.E. headlamp? Do you have any pics ? I have considered changing over to a LED headlamp but I don't want it protruding past the trim ring or having to use frenched rings.
That is correct. I didn't want it protruding either and am not a big fan of the "frenched" ring. Had a look at the stock setup and it's not like it's sealed up or anything back there inside the fairing...all open behind the headlight anyway. I just took my time and trimmed away a bit at a time until it all fit together flush with the stock trim ring. Ended up trimming away quite a bit because the LED is pretty big on the backside. Fits & looks like stock now.
Apparently the HD mounting ring from a 2012 CVO Ultra (68124-04B) works as well as it's open in the back. I can't confirm it though...plus it's pretty "spendy" at $51.99! Figured a bit of time with my tin snips was free.
Sorry I didn't take any pics and seeing as we're in the dead of winter here now and the bike is stored, I won't be able to take any pics any time soon.
Again, for the price, I'm very satisfied with these Sunpies!
Old Jan 15, 2018 | 07:30 PM
JeffJA's Avatar
JeffJA
i used a Dremel to cut mine, took about 10 mins, looks fine and it was free!
Old Jan 16, 2018 | 11:29 AM
HM_SanDiego's Avatar
HM_SanDiego
I just installed the Sunpie headlight and aux light set on my 99 Road King last night - love them, and can’t wait to go for a ride at night.
I did get and install with the Sunpie mounting ring for the headlight. When reading the kit application fitment, the older bikes need the headlight ring, while newer bikes, I believe 2014 and newer, install without the ring. Read and choose carefully - I did not read carefully, and I had to order the ring separately, which cost me $10 extra that I could have saved by ordering the kit with the ring included.
What I did learn with this is -
1 - I absolutely needed the ring for the headlight on my bike, and this allowed for a clean install without cutting anything
2 - when mounting the headlight, I found some feedback stating the best install results were to tighten down the 3 spring loaded adjustment screws on the Sunpie mounting ring. This allowed a flush install of the outer trim ring the nacelle.
I also have the visor on my headlight and I’ll need to play with this a little bit, potentially. When I removed my oem headlight, the visor is/was installed with 2 sided tape to keep it in place. I have it installed with the tape left on the visor from removing it, as kind of a padded spacer, but will apply new tape if needed, if the visor does startt moving around.
So, the Sunpie Daymaker LED headlight kit, with the 2 fog/passing/aux lights = $96.98 - feee shipping and no sales tax
The headlight mounting ring bracket = $25.99 - free shipping and no sales tax
My total = $122.97
Kit cost with headlight ring/bracket = $112.99 free shipping and no sales tax
Old Jan 16, 2018 | 01:58 PM
b1gj0n44's Avatar
b1gj0n44
Do you have the visor or the extended trim ring that goes around the headlight? I have the ring that goes around and is pinched together at the bottom with a screw, but Im not able to get it secured with the new headlight in.
Old Jan 16, 2018 | 02:31 PM
HM_SanDiego
I have the visor with the nacelle trim ring that goes over the visor, over headlight, onto the nacelle, and is secured at the bottom center with a single screw inward, into the hole at the bottom of the headlight man using ring, which required a slightly larger diameter course thread screw.
hope that helps
Old Jan 16, 2018 | 04:14 PM
Nokkon Wud's Avatar
Nokkon Wud
Mine bolted right on the 03 RK. Love them!
Old Jul 18, 2024 | 01:12 PM
CecilH's Avatar
CecilH
Stage I
My 1993 ultra classic is going to require some extensive modifications apparently since the headlight won't fit in the bucket due to the back of the light being very large. About 2 inches roughly of the bucket will have to be removed all the way around to fit. I'm wondering if it's really worth the time of making the modifications, am I going to get that much more light out of this fancy light or am I wasting my time?
Old Jul 18, 2024 | 01:51 PM
Goose_NC's Avatar
Goose_NC
Hoping they figured it out 6 1/2 years ago.
Old Jul 21, 2024 | 09:29 AM
Ultra103's Avatar
Ultra103
You may not get many replies without starting a new thread, bunch of grumps here who think knowledge has an expiration date.
I have the Sunpie lights on my bike, I replaced the Harley branded LED set with them. Good lights and certainly an upgrade, but I'm not sure I'd go hacking on my bike to install one. I tend to find a used part to hack for things like that, so I have the original on the shelf. It doesn't hurt as badly if I slip and damage it then.
honda450r
May 13, 2017 11:18 PM
VTGlideRider
Sep 28, 2016 11:44 PM
lostrider06
Jul 8, 2015 07:33 AM
looneytune
2014-2024 Touring Models
Jun 21, 2014 01:54 PM
Shvlhdz
Jun 10, 2012 07:41 AM
