Got a fork question
Old Jan 21, 2018 | 11:06 AM
DTTJGlide's Avatar
DTTJGlide
Yes I forgot to say you need the same year axle as the wheel you're using, you can use your 07 calipers as long as you use your 07 rotors. I recommend switching to the Brembo calipers,but you should also use the later master cylinder from a Brembo equiped bike.
Old Jan 21, 2018 | 11:25 AM
DTTJGlide's Avatar
DTTJGlide
The rotors are a different diameter, old is 13.5, new Brembo is 13.8. I did the whole swap on a 2000 bike & there are a couple of different ways to accomplish it, custom spacers & you can use your stock M/C but you have to either clean that & all lines & switch to Dot 4 brake fluid or disassemble the Brembo calipers & clean them. If you're going to try old & new you need to clean very well with brake clean as the 2 different fluids don't mix, you'll end up with "jello" in your system. Since the lowers are the same I think the best way is to use everything from the year wheel you plan to use, calipers, master cylinder, spacers, bearings, & axle. All of those things are also the same up through 2018, only the fork lower changed for the 49mm tubes.
Old Jan 21, 2018 | 11:43 AM
Radicult's Avatar
Radicult
Ive been told that my old rotors won't bolt on the enforcer??
Radicult's Avatar
Radicult
And I mean my 07 rotors
Old Jan 21, 2018 | 12:00 PM
DTTJGlide's Avatar
DTTJGlide
Sorry you're right, when I first did the swap I used the 18" front from a 2011 SG, sorry for the confusion. I still stand with my recommendation to use all the late model stuff, you can usually find the stuff used on ebay, if you're interested I do have a full Brembo conversion left after I sold my 2000, you can PM me if you like, hopefully you got the rotors with your wheel as they are pretty pricey.
Old Jan 21, 2018 | 12:10 PM
Radicult's Avatar
Radicult
Will the 2000 kit fit my 07?
Old Jan 21, 2018 | 12:16 PM
Radicult's Avatar
Radicult
Sent you a PM
Mnvrod
Jun 21, 2019 01:49 PM
jgcable
Dec 31, 2013 12:34 PM
GPz11
EVO
May 22, 2013 01:10 PM
niczumbo
Aug 12, 2011 09:02 AM
4t8
Sep 20, 2010 06:26 PM
