Battery Recommendation ?
Old Jan 21, 2018 | 11:15 PM
C908's Avatar
C908
Default Battery Recommendation ?
I may need to replace my Yuasa AGM battery, can anyone recommend a brand they have had good luck with ? In the past I have had Interstate and the stock Harley batteries. I was kind of thinking this time about trying a Deka AGM battery. Thanks for your comments.
Old Jan 22, 2018 | 01:28 AM
svarnster's Avatar
svarnster
thunder volt by ultima. I got 7 yrs out of it and it is still cranking the lawn mower a year and a half later. The deka I replaced it with is already suspect and has been charged twice this winter.
Old Jan 22, 2018 | 04:18 AM
RK_Classic's Avatar
RK_Classic
Batterymart.com big crank, with all the extreme cold weather we have had for the past month my bike fired right up without a problem. the battery have the beefy lug connections not the crappy square type that you have to use nuts & bolts.
rk classic.
Old Jan 22, 2018 | 06:33 AM
Rogue8Man's Avatar
Rogue8Man
Just went through this myself last week with a Deka that was 11 months old. Ended up ordering a Yuasa GYZ32HL through PhatPerformance. Hopefully this one will fair better....
Old Jan 22, 2018 | 08:28 AM
Chuck U. Farley's Avatar
Chuck U. Farley
I just ordered the same from Amazon, $139 plus free shipping. I heard good thing about the 500cca. Will give it a shot.
Old Jan 22, 2018 | 09:02 AM
Spy11's Avatar
Spy11
Odyssey makes a great solid state battery that is expensive but really lasts.
Old Jan 22, 2018 | 09:35 AM
Sturgis67's Avatar
Sturgis67
Originally Posted by rk_classic
batterymart.com big crank, with all the extreme cold weather we have had for the past month my bike fired right up without a problem. The battery have the beefy lug connections not the crappy square type that you have to use nuts & bolts.
Rk classic.
^^^this one right here^^^
have used big crank from battery mart for years, never any problems.
Old Jan 22, 2018 | 10:14 AM
C908's Avatar
C908
In response to Chuck U Farley the battery you just ordered is the one that died on me after 1 year 9 days. I also ordered it through Phat Performance, waiting for them to open so I can call them. My bike is always garaged and hooked up to a battery maintainer.
Old Jan 22, 2018 | 10:24 AM
C908's Avatar
C908
I noticed in addition to the Big Crank that has been mentioned there is also a Mega Crank.
Old Jan 22, 2018 | 10:31 AM
hbsoldier3's Avatar
hbsoldier3
I have that battery in two bikes, I thought it was the cat's meow. I have my suspicion now. Installed one a year ago, and now it cranks like a HD battery. It first it turned over very fast, now I get the hesitation then crank. I think I am with the OP on this one. They have little to no warranty. You have to contact the seller, which is ok, but Yuasa does not back the seller. At least that is what I am led to believe, somebody prove me wrong, please.
