I finally got some time to put a few miles my '02 RKC yesterday. I got off the back roads and was going to make a thunder run home down the turnpike. As I ran up past 65 mph the front wheel seemed to start bouncing. I looked down and it looked like it was hopping up and down pretty good. I had no side to side wobble. At 70 mph it got worse so I backed off to 60 mph and it seemed to settle the 75 miles home.[:@]
The previous owner put a set of Avons on HD Chrome Spoke Wheels. I had the cold pressure at 35 psi. The wheels have wheel weights installed. The bike has 9100 miles on the clock.
Hi! Just signed up on this forum, cause I wanted to help with this bouncing front wheel issue, which I had for a while. Well, I found the problem yesterday, after brake pads change, it became obvious: the rotor is like an 8 shape and during the ride it hits periodically the brake pads causing the bounce. If someone still has this problem that`s a reason to be investigated.
Welcome to the forum.
The original poster may not even have that bike anymore? This thread's last post was 14 years ago...
They got Harleys in Greenland? Didn't even think they had roads.
