Road King Question
Old Jan 31, 2018 | 01:50 PM
MUDDSTER's Avatar
MUDDSTER
6th Gear
Default Road King Question
I have an 08 RK classic and was thinking of changing out the back pac on it (hard leather case). I found an 04 ( Electra Glide Classic) full set up (Tour Pac) with wrap around seat for wife and same colour as bike . My question is will that fit the bike ? It’s not a quick release but was hoping to maybe swap over existing to the new one. Am I wrong in thinking I can do that ??
Old Jan 31, 2018 | 02:07 PM
RK_Classic's Avatar
RK_Classic
Have not don't it myself but I see no reason why it wouldn't work if you are going to transfer the 04 TP to your mounting brackets, You may need to drill new holes in the 04 TP to make it fit, but I see no issues.
rk classic.
Old Jan 31, 2018 | 02:15 PM
beary's Avatar
beary
I think you are talking about the tourpack. Yes, you can switch them out, but the reason the RKClassic tourpack is different is because the leather RKC saddlebags open differently. They open toward the fender or tourpack and will be restricted somewhat with the EG tourpack. They still open a lot, but not all the way.
Beary
Old Jan 31, 2018 | 02:28 PM
HopOn's Avatar
HopOn
I'm trying this myself 04RKC trying to fit a Tourpak from an 06 Electra and having an issue with it fitting with the Tallboy seat I have on mine. I have the quick disconnect rack and it lines up right just won't fit due to the seat. I'm looking for options to raise the tourpack on the mount using spacers for additional height and also looking into the Kuryakyn adjustable mount - interested to see if yours works out better
Old Jan 31, 2018 | 02:38 PM
Fireball Jack's Avatar
Fireball Jack
How much do you need to raise it?
Old Jan 31, 2018 | 05:09 PM
MUDDSTER's Avatar
MUDDSTER
6th Gear
Beary
good point never thought of that. So the lid will contact the tour pac when opening but not enough to impede putting stuff in.
Old Jan 31, 2018 | 05:11 PM
MUDDSTER's Avatar
MUDDSTER
6th Gear
that’s probably just an issue with your seat , or I hope it is. Lol. Or I’ll have another issue to deal with.
Old Jan 31, 2018 | 07:53 PM
giacomo56's Avatar
giacomo56
Usually tour pak have a second set of holes that you can move it further back.....look on the bottom it should have two sets of holes....well at least the King Tour pak does.....but I certainly wouldn't move it up but rather back an inch or so....
Everything is doable, i just moved my '05 RK tour pak unto my '17 SGS....looks fabulous !!!
Old Feb 1, 2018 | 02:44 PM
HopOn's Avatar
HopOn
Just a guess at this point but probably 1.5"
bigred292
May 18, 2014 08:18 PM
hambone51
Jan 2, 2014 11:29 PM
djw
Dec 11, 2009 04:34 PM
Cowboy Tom
Mar 15, 2007 09:03 AM
Iceman
Aug 29, 2005 01:46 PM
