Help Relocating CB and AM/FM Antennas
Old Feb 4, 2018 | 07:07 AM
kevbo's Avatar
kevbo
Default Help Relocating CB and AM/FM Antennas
I'd like to create a second mount point for my antennas for when my tour pack is removed. Beneath the my seat I've spiced both antennas so I simply just connect desired path. I see that there are couple of options here as far as mounts. One is real low by the lip light where there a couple of larger torque bolts, the other there mount points between the bags and the fender (pic attached). I think that's a sleeker look (yes i'm weird in that I like the antennas sticking out). So I'm looking for mounting hardware for both AM/FM and CB for both sides. Not much out there so any help would be appreciated!
Attached Thumbnails Help Relocating CB and AM/FM Antennas-help-with-mounts.jpg
Old Feb 4, 2018 | 07:10 AM
Iceman24's Avatar
Iceman24
Have you considered "hidden" antennas? If not & you still want the whips, look at getting FLHX antenna mount brackets...they should work (same bike design).
Old Feb 4, 2018 | 01:10 PM
Ssitruc's Avatar
Ssitruc
I used a hidden FM antenna on mine. For the CB I added the relocation mounting hardware that mounts at the bottom of the slots between the bags and fender, part 76000308. I think they sell the same type of relocation mount for the FM antenna also. It’s easy to move the antenna when I’m switching the tour pack off or on and I just put a thread saver on which ever mount I’m not using.
Old Feb 4, 2018 | 05:46 PM
kevbo's Avatar
kevbo
I like the look part number 76000308 offers and it appears it would work for me on a 2012 FLTHK. I like the look of the street glide mounts more so I'm goiing to try find these for AM/FM and CB (Left and Right respectively).
Old Feb 4, 2018 | 06:09 PM
AFMM3's Avatar
AFMM3
I used these on my 2008. http://www.pingelonline.com/harley-d...ing-models.asp
Old Feb 4, 2018 | 07:17 PM
kevbo's Avatar
kevbo
Can you send a pic? I have one of these mounts but was planning on returning it to use the other mounting bracket like i showed in the previous pic.
Cozz
Aug 1, 2016 01:44 PM
bornindadamnusa
Jan 6, 2016 07:45 AM
Tom T-Bird
Jun 27, 2013 08:15 PM
jgreg65
Feb 2, 2010 09:47 AM
bigbean78
Nov 4, 2007 07:25 AM
