Communication system 08 Ultra
Old Feb 5, 2018 | 09:10 AM
bwood's Avatar
bwood
Default Communication system 08 Ultra
So i know this may have been asked before but, I have an 08 Ultra and i need some coms for me and my wife to talk to. Question: on the back there is a volume button but i do not see a port is this something that i have to add. Question: i want to be able to talk to her but also use my radio and cb so i need to stick with the plug in to the 7 pin ? Opinion: or would it be better to go blue tooth with wife and get a CB mike to plug in if i needed it. Planning a trip to DC at the end of May with a large group and just trying to work things out. I know the blue tooth adapter that replaces your air temp works with GPS and phone but i dont really want to give up my radio and cb. Thanks for any advise.
Old Feb 5, 2018 | 09:46 AM
Nute's Avatar
Nute
Everything you want to do can be accomplished with your onboard communication system. You will need a headset for both you and your wife. Should be a 7 pin connector for passenger located left side under TP.
Old Feb 5, 2018 | 01:30 PM
14GuineaPig's Avatar
14GuineaPig
The headset socket should be on the left side under the left side rear speaker.
You can go to the HD Service Info Portal and view your owners manual online. Look under Advanced Audio .... Passenger Controls
https://serviceinfo.harley-davidson.com/sip/index
Old Feb 7, 2018 | 08:28 AM
bwood's Avatar
bwood
Ok I found the hole in the tour pack but because the pack is removable the PO rolled the wire up and stuffed it under the seat. Is there a relocation bracket or a DIY one for the connector.
Old Feb 7, 2018 | 11:47 AM
14GuineaPig
Off the Wall made something up for his 2014 Limited so that he had passenger communication without the tour pak. Here's a link to his thread:
https://www.hdforums.com/forum/new-r...-tour-pak.html
TimHixson
Apr 22, 2013 06:32 AM
bill1nat
Oct 3, 2010 10:28 AM
botlefedpony
May 7, 2010 05:48 PM
Conehead
Jan 3, 2009 10:53 AM
mrbrown663
Jul 26, 2007 08:39 PM
