Lift table question
Old Feb 17, 2018 | 10:01 PM
TSheff's Avatar
TSheff
[QUOTE=hbsoldier3;17101507]
For the majority of my work on my FL models, I go from the top of the crash bar, or the bottom of the crash bar, near the floor board mount, and pull it into the wheel chock.... both sides. I attach the straps to the lift table, wide enough, that the straps don't touch the front wheel/fender. With a quality wheel chock, this will work for most jobs.
If I'm really gonna be wrenching hard (like compensator), I'll also put a good scissor jack under the bike and lift it to engage both frame points and take a little of the bike's weight. This will help stabilize it
+1 on the scissor jack, and nice choice for a table lft you got there.
Like this.
Old Feb 18, 2018 | 10:59 AM
Softy 103's Avatar
Softy 103
I have never felt the need to tie mine down on the lift table, just use the wheel chock
Old Feb 19, 2018 | 09:35 AM
CyGlide's Avatar
CyGlide
This is how I do mine. For normal table use and for rear tire removal I tie down over the crash bar and frame. For front tire removal I tie down from the rear of the frame above the footpegs. I also clamped a 2x4 behind the rear tire to act as a wheel chock, then I also leave the front straps on but loose while raising the front, then just take them to snug to provide extra stability while the bike is on the jack.
Old Feb 19, 2018 | 09:40 AM
CyGlide's Avatar
CyGlide
I forgot to mention that when I do the front end work I wrap a bungee cord from the crash bar to the rear brake pedal so that the rear brake is applied. Last thing I want is that bike shifting or rolling while up in the air without a wheel on it. Might be over kill but it takes 30 seconds to do.
Old Feb 19, 2018 | 10:07 AM
dawg's Avatar
dawg
I like using my floor jack for front wheel removal and the table lift for rear, just my preference.
Old Feb 19, 2018 | 10:37 AM
Puglia10's Avatar
Puglia10
Take the extra 2 minutes to save thousands of dollars and tie it down. Ive seen it happen a few times....These are famous last words. Wheel chock isnt enough, ESPECIALLY for a big touring bike...
Old Feb 19, 2018 | 01:16 PM
Softy 103's Avatar
Softy 103
Maybe for some major wrenching, but for just normal servicing I have never tied one down, had a table for 5+ years and no problems
Old Feb 21, 2018 | 10:06 AM
hattitude's Avatar
hattitude
That's how most people do it.... the odds are completely in favor of you never having an issue...
But for me, it's not the odds, but the stakes..... if the bike should fall, someone can be hurt, and it will probably cost a bunch to fix...
And of course, the wheel chock will work just fine.... until the one time it doesn't..
I use the two straps on the front , pulling into the wheel chock for 90% of my lift table work.... takes only a minute or so to set up.
But when the big breaker bar comes out, large torque values are used, or when removing heavy parts that will affect balance (wheels)... I take some extra steps...
Old Feb 21, 2018 | 10:54 AM
2black1s's Avatar
2black1s
I'm in this camp.
Old Feb 21, 2018 | 01:32 PM
BKR549's Avatar
BKR549
Originally Posted by hbsoldier3
What lift and wheel chock is that?? What's the max lift height?
Thanks
