Lift table question
Old Feb 17, 2018 | 05:44 PM
Inop's Avatar
Inop
Default Lift table question
You guys with lift tables where do you put you tie downs? I tried the handle bars but it hits the inner fairing on my street glide.
Old Feb 17, 2018 | 05:45 PM
2500hdon37s's Avatar
2500hdon37s
get some soft ties and go around the lower triple tree like you would if strapping it down to a trailer.
Old Feb 17, 2018 | 05:50 PM
svarnster's Avatar
svarnster
I go across top of the fender support with soft cloth or towel under strap
Old Feb 17, 2018 | 05:54 PM
ROCKOUT Rocker Products
Sponsor
I use the soft tiedowns & go to the crash bars.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Feb 17, 2018 | 06:10 PM
Inop's Avatar
Inop
Thanks guys I just googled it and found some rhino straps.
Old Feb 17, 2018 | 06:14 PM
aaa1988's Avatar
aaa1988
I put on kuryakyn 924 tie down brackets
https://www.jpcycles.com/product/503...-glide-and-cvo
Old Feb 17, 2018 | 06:25 PM
Hoginedgewood's Avatar
Hoginedgewood
Foot pegs. But you need a scissor lift.
Amazon Amazon
Old Feb 17, 2018 | 06:27 PM
hbsoldier3's Avatar
hbsoldier3
Get some of these: https://www.harley-davidson.com/stor...-brackets#tabs
Old Feb 17, 2018 | 09:34 PM
hattitude's Avatar
hattitude
For the majority of my work on my FL models, I go from the top of the crash bar, or the bottom of the crash bar, near the floor board mount, and pull it into the wheel chock.... both sides. I attach the straps to the lift table, wide enough, that the straps don't touch the front wheel/fender. With a quality wheel chock, this will work for most jobs.
If I'm really gonna be wrenching hard (like compensator), I'll also put a good scissor jack under the bike and lift it to engage both frame points and take a little of the bike's weight. This will help stabilize it
On my Springer, or any FX model, I go from the the front of the frame, around the upper attachment point for an engine guard, and pull into the wheel chock... both sides. I attach the straps to the lift table, wide enough, that the straps don't touch the front wheel/fender.
I don't have a pic, but if the front wheel chock needs to be removed, and can't be used, I use my scissor jacks. I put both scissor jacks (I have two, so I use them both as a redundant safety measure) under the frame, lift the bike and stabilize the bike with straps. I go from the left hand passenger peg/floorboard/saddlebag guard, over the seat, to the right side of the lift. I repeat the procedure from the right side of the bike, over the seat, to the left side of the lift.
I saw the aftermath of a friend's bike that fell over & off a lift table. I take all the time I need, to feel the bike is secure, before I start wrenching on it...
Old Feb 17, 2018 | 09:53 PM
hbsoldier3's Avatar
hbsoldier3
[QUOTE=hattitude;17101431]For the majority of my work on my FL models, I go from the top of the crash bar, or the bottom of the crash bar, near the floor board mount, and pull it into the wheel chock.... both sides. I attach the straps to the lift table, wide enough, that the straps don't touch the front wheel/fender. With a quality wheel chock, this will work for most jobs.
+1 on the scissor jack, and nice choice for a table lft you got there.
