Wrong Gas Tank
Old Feb 20, 2018 | 06:16 PM
JakePie's Avatar
JakePie
Default Wrong Gas Tank
Hello,
I am new to Harley's and bought my first one over the summer. The bike was in ok condition, but I got a good deal on a whole tin set. I just noticed that the tank is for an carb bike and not EFI. I know you can convert from the EFI tank to Carb but can you do the opposite? I am about 99% I know the answer, but a little reassurance will help. Thank you.
Old Feb 20, 2018 | 06:23 PM
dawg's Avatar
dawg
Assuming this is for your 2000, go all the way and convert your MM to a carb!
Old Feb 20, 2018 | 06:30 PM
JakePie's Avatar
JakePie
I thought about it, but at this point I have spent too much money as it is HAHAHA.....I'm also trying to pay for a wedding while rebuilding the bike.
Old Feb 20, 2018 | 06:40 PM
nobodyknowsme's Avatar
nobodyknowsme
Put the wedding on hold and get your priorities straight!!!
While you are at it get a pingel petcock.
Old Feb 20, 2018 | 07:40 PM
JakePie's Avatar
JakePie
Is there a pinger petcock that will work for sticking with the EFI?
Old Feb 20, 2018 | 08:20 PM
OlAndrew's Avatar
OlAndrew
No petcock. EFI has a fuel pump, regulator and some other stuff in the tank, and the tank has a fairly large opening in the top for all that to fit through. There's a pressure feed and return fuel line on quick-disconnect fittings on teh bottom of the tank that go to the injectors.
Old Feb 20, 2018 | 08:21 PM
FPV's Avatar
FPV
Might be but not that I'm aware of. Where's the fuel pump going to go?
Edit: a minute late on that reply.
Old Feb 21, 2018 | 05:13 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
While it technically be done, even using a conventional petcock, it's probably not worthwhile doing it. Just get a fuel injected tank, complete, at a swap meet and you'll be at least hours ahead on fabrication work.
Old Feb 21, 2018 | 11:05 AM
Bubba Zanetti's Avatar
Bubba Zanetti
It can be done but not without pretty significant modification. Sell the tank and buy one for EFI
Old Feb 21, 2018 | 11:30 AM
svarnster's Avatar
svarnster
how much for the tank?
