oil cooler
Old Jun 21, 2007 | 04:10 PM
  #31
tbradley's Avatar
tbradley
Default RE: oil cooler
nvsteve,
Where can I find out more about the new #2300 10 row Jagg Oil Cooler and what other parts I need to order with it? I looked on the Jagg site and as you stated, it is not there yet.
I assume I need an adapter and the cooler, maybe the bypass.... anything else?
Old Jun 21, 2007 | 04:44 PM
  #32
usecotton's Avatar
usecotton
Just got myJagg low mount 10 row installed. Got them from Shooter64....he will do you right. Send him a PM. Italked toJagg directly before buying and they suggested not going to the added expense of a thermostat.So I just bought the adapter and cooler. Their reason for no thermostat was that it was something else to breakdownand it wasnt that usefullexcept in cooler climates.In NC the weather is normally warm enough the therm would open fairly quickly anywayso I decided to try it that way. Gonna just cover the cooler during cold weather if need be.
Old Jun 21, 2007 | 05:14 PM
  #33
Lost1's Avatar
Lost1
ORIGINAL: usecotton
Isn't that the one that mounts in the same location as the H-D cooler? How was the install- fairly straightforward? Any problems?
Old Jun 21, 2007 | 05:50 PM
  #34
ezlife's Avatar
ezlife
ORIGINAL: Bushy
7/16" allen socket!!!!!!!7/16" allen socket!!!!!
Breath in...deep breath...breath out. Breath in...deep breath...breath out.
Man, gotta learn to live life on the ezzz side. LoL
Old Jun 21, 2007 | 06:12 PM
  #35
PosseRider's Avatar
PosseRider
Save your $$ and make one out of your crash guard.
Old Jun 21, 2007 | 07:27 PM
  #36
nvsteve's Avatar
nvsteve
ORIGINAL: tbradley
nvsteve,
The best way to find out is by calling them direct. I got lucky when I called and got the general manager. Yes you need the adaptor and he talked me out of the bypass. I ordered the anti spin fitting but got frustrated with installing it so gave up. If I have trouble getting the filter off I'll try again. Fairly easy install, just takes time.
Ordered mine from M&M at a good discount. Sent Shooter64 an email and never heard back.
Old Jun 21, 2007 | 08:06 PM
  #37
Softtail Bob's Avatar
Softtail Bob
ORIGINAL: Akitakoi
Yea I caught that tip about needing a 7/16", usedthe bolt with 2 nuts trick. Thanks
The ports on my cooler are on the wrong side. Did I get the wrong one? Part # on the box is right.[&:]Box was sealed from the factory.[&:]
Can you take a pic of the cooler installed? It should look just like the one pictured above. If not I would call the part department and then e-mail them a pic so they can replace it with the correct unit. What was the part number on the box? I feel bad they screwed up you order after I told you about them. Let me know and I will help anyway I can.
Old Jun 21, 2007 | 10:44 PM
  #38
usecotton's Avatar
usecotton
The install of the Jagg was very easy. You have to remove 5 or 6 allens to disassemble the adapter and then put the pieces back on the eingine one at the time. (only 3 pieces)
The cooler is a very simple two bolt install. They send plenty of hose and the adapter is adjustable to be sure no kinks in hose.
Whole install took about 1 hr.......a real piece of cake.
Put the McEwan oil temp guageon at the same time...Another quality piece. It already has the oil pan adapter so there is no need for bushing and is already wired to use the air temp wiring harness. Just have to run the supplied wire from sensor to guage.A little tight behind fairing metal bracket and guage hole but it works with just a littlepatience.
Old Jun 25, 2007 | 06:11 PM
  #39
otcauctions's Avatar
otcauctions
As noted in this thread. Contact Shooter64 he will take care of you. He responded to me within a couple of hours and provided me with a deal better then anything retail and better then I could find on eBay
This is an honest guy they just wants to help out the forum members!
Old Jun 25, 2007 | 07:49 PM
  #40
tarheelrdr's Avatar
tarheelrdr
How hot does it need to be before an oil cooler is needed using syn oil, I have and 04 ultra w/113 ci. and have seen 255 degrees while riding in a group of about 75 bikers. Does anybody know when it gets to be a problem?
OldPhat
Jul 15, 2023 11:16 AM
Bart van der Meulen
2014-2024 Touring Models
16
Aug 13, 2015 05:48 AM
nmfxstc
Oil Archive (no new posts)
Jun 18, 2008 10:21 AM
texas725
Mar 24, 2007 11:45 AM
redhwk44
Jul 25, 2006 02:40 PM
