Leak down test.
Old Mar 1, 2018 | 10:54 PM
Mhoffer's Avatar
Mhoffer
No tuner.
Old Mar 1, 2018 | 11:42 PM
Max Headflow's Avatar
Max Headflow
It's definitely too rich.. I don't know what could cause it on MM Efi.. Maybe a leak injector, bad tps, or temp sensor but they are just a wild assed guess..
I'd be pretty confident that it is fueling over a bad motor tho plugs running that rich can screw up the cylinders.
Old Mar 2, 2018 | 05:27 PM
GTK's Avatar
GTK
Put a new set of plugs in engine and remove your oil treated air cleaner element and drive bike for a few miles slow and fast speeds and then look at plugs again.
Old Mar 3, 2018 | 11:06 AM
Mhoffer's Avatar
Mhoffer
This morning I pulled off my cylinder tempt sensor. I rigged it up to a pot of water and my volt meter. Turned the heat on to simulate a engine warming up and my volt meter on ohms it smoothly went from around 4.xxx cold to .21 boiling hot. I don't know what the parameters are for a known good one. But I did notice mine moved smoothly through the heat range no jumping around on warm up or cool down. So I think my sensor is good.
djs
Milwaukee Eight (M8)
32
Nov 27, 2021 05:30 PM
Rtlang
Shovelhead
Feb 16, 2014 05:31 PM
Mike in Oregon
Jul 2, 2010 06:57 PM
roadglide65
Exhaust System Topics
Aug 1, 2007 06:49 PM
98fxd
Aug 4, 2005 07:04 PM
